Define Load Step: CLOAD-Force/Moment on: Nodes or Geometry |
The Define CLOAD-Force/Moment on: Nodes or geometry option allows you to define *CLOAD (force or moment) on individual nodes or geometry. The concentrated loads created on nodes have special graphical display in Engineering Solutions. Loads created on geometric entities such as surfaces, lines, or points are automatically mapped to FEA mesh on export. They can also be mapped using the Map Loads on Geometry button.
The Define tab for Define CLOAD-Force/Moment on: Nodes or geometry contains the following buttons:
Define from 'Forces'/‘Moments’ Panel |
Opens the Forces or Moments panel to create/update a CLOAD. To create a CLOAD on nodes, go to the create subpanel, select nodes using the switch, pick the desired nodes from graphics, select the global/local system, select a vector, input a magnitude, and click create. To create a CLOAD on geometry, go to the create subpanel, select points using the switch, pick the desired geometry from graphics, select the global/local system, select a vector, input a magnitude, and click create. Note:
Map Loads on geometry |
Opens the Loads on Geom panel to map loads on geometry to FEA mesh entities. Click Map loads to map all geometric loads in the current load collector to FEA entities. Note:
