Engineering Solutions
Load Step: CLOAD: Define Tab
The Define tab allows you to define *CLOAD (force or moment) cards on individual nodes or geometry (points).  You can also define the *CLOAD on node sets.
You can define CLOAD-Force/Moment on nodes/geometry or on node sets.  For Define CLOAD-Force/Moment on:, the following options are available:
Nodes or geometry
Node sets
The layout of the Define tab changes based on your selection.
See Also:
Load Step: CLOAD
