Engineering Solutions
Global Mesh
Global Mesh
Global Mesh
This panel is a continuation of the Global Organize & Cleanup panel, but you can mesh the remaining "global" geometry that was not covered by any of the previous meshing panels.
tet_proc_mgr_09
On this panel, you can specify the Element Size that you want to use when meshing all of the remaining global geometry. You can also choose the type of element that you wish to use; trias are the default.
Clicking Mesh creates a mesh using the specified element size and type on all remaining "global" geometry. If you do not like the results, clicking Delete Mesh removes mesh from all such geometry, without affecting the specific items already meshed in previous stages (such as holes or user-defined features).
Click Prev to return to the Global Organize & Cleanup panel, or click ACCEPT or Next to continue. You can also click on a specific task in the Process Manager to go to the appropriate panel.
