These panels are located inside of the Safety module.
Creates or updates mass elements. |
Create or modify block the entities used by many crash solvers. |
Verifies the quality of elements. Checks warp, aspect, skew, angles, length, jacobian, connectivity, and duplicates. |
Creates control volumes. |
Allows you to rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly. |
Creates and modifies single or multiple ellipsoids and cylinders. |
Creates, reviews, or updates joints. |
Creates and modifies interfaces that define a contact or sliding surface. |
Define kinematic joints between two local coordinate systems to connect two multibody collectors |
Create rectangular, planer surfaces for use in multi-body analysis. |
Creates and updates blocks of entities used for output requests. |
Checks groups for initial penetration problems. |
Creates and updates rigid walls. |
Allows you to create and route seatbelts onto a dummy. |
Creates and edits sensors. |
