The Define tab allows you to select the slave surface, master surface, and surface interaction for the *SHELL TO SOLID COUPLING card. You can also review the selected surfaces or create new ones.
The Define tab contains the following options:
Surface |
The Surface: field contains a list of the existing surfaces. Select a slave surface from the list or use the … button to open the Entity browser to select a surface. Click the Slave>> button to add the surface as a slave to the table of selected surfaces. Click the Master>> button to add the surface as a master. Click <<Remove to remove any selected surface from the table. You can add multiple sets of surfaces to the table. Click the New button to create a new surface. Once you have specified the surface properties, the surface appears in the drop-down list, where you can select it and add it to the table. For a description of defining surfaces, see Element Based Surface or Node Based Surface. The Review button highlights the selected slave surface in white and displays it through solid mesh in performance graphics in the window. If the surface is defined with sets, the underlying elements are highlighted. Right-click on Review to clear the review selections. |
Note that if you create multiple pairs of contacts, they will appear on the Interface tab in separate entries using the same name.
