Engineering Solutions
Shell to Solid Coupling: Parameter Tab
The Parameter tab allows you to define optional parameters for the contact pair card.  Options vary according to the template loaded.
The supported parameters are:
For Standard.3d/2d template and Explicit template
INFLUENCE DISTANCE and POSITION TOLERANCE. To add them, enable the checkbox and then add an appropriate value. See the Abaqus Online Documentation for a detailed description of these parameters.
contact_mgr_shell_to_solid_parameter_tab
