Engineering Solutions
Shell to Solid Coupling
The Shell to Solid Coupling dialog allows you to define the *SHELL TO SOLID COUPLING card. There are two tabs in this dialog.
Define
Parameter
contact_mgr_shell_to_solid
The Contact Pair dialog contains the following buttons:
OK
Updates the database with the changes and closes the dialog.
Apply
Updates the database with the changes without closing the dialog.
Cancel
Closes the dialog without updates.
