Engineering Solutions
Surface Interaction: Gab Radiation Tab
The Gap Radiation tab allows you to define a viewfactor versus distance relationship for heat transfer between surfaces which are very close to each other.
Emissivities for both involved surfaces can be defined. By default the dialog offers two datalines to define a function of the viewfactor depending on the gap with between two surfaces. The length of the table can be increased by changing the Number of datalines field.
gap_radiation_tab
