The Surface Interaction dialog allows you to define the *SURFACE INTERACTION card with corresponding cards:
• | *SURFACE BEHAVIOR |
• | *CONTACT DAMPING |
• | *FRICTION |
• | *GAP CONDUCTANCE |
• | *GAP HEAT GENERATION |
• | *GAP RADIATION |
This dialog contains the following tabs:
The Surface Interaction dialog contains the following buttons:
OK |
Updates the Engineering Solutions database with the changes and closes the Surface Interaction window. |
Apply |
Updates the Engineering Solutions database with the changes without closing the Surface Interaction window. |
Cancel |
Closes the Surface Interaction window without any update. |
