The Contact Damping tab allows you to create *CONTACT DAMPING cards with corresponding parameters and data lines. The supported parameters are: Definition and Tangent fraction (explicit only). The two definition types supported are: Damping coefficient and Critical damping fraction (explicit only). The data item entry options change based on the current template. See the Abaqus Online Documentation for a detailed description of these parameters.
