Engineering Solutions
XY Plotting Panels
XY Plotting Panels
XY Plotting Panels
Axis Labels
Edits axis label information.
Axis Scaling
Modifies plot axes.
Border
Edits the border of an XY plot.
Curve Attribs
Creates and edits curves.
Edit Curves
Creates or edits new or existing curves from files or math expressions.
Grid Attribs
Edits grid information.
Grid Labels
Edits grid label information.
Integrate
Allows you to integrate a curve.
Legend
Edits the plot legend.
Plot Titles
Edits plot titles.
Plots
Creates new single or dual plots and allows you to select curves to include on the plots.
Query Curves
Allows you to find the x and y values of a point in a curve.
Read Curves
Allows you to input an xy data set from an ASCII file.
Results Curves
Allows you to create curves by extracting data from a HyperMesh results file.
Simple Math
Allows you to perform simple math functions on a curve.
Window
Controls xy plot window size and placement.
