The Beam, pipe, or truss elements option allows you to define the *SURFACE card for individual beam, pipe and truss elements. In the graphic area, these faces are displayed by special contactsurface elements. These contactsurface elements have their own normals to define the SPOS and SNEG faces. The contactsurface with normals along the underlying element normals define the SPOS faces. In contrast, the face with opposing normals defines the SNEG face.
The Beam, pipe, or truss elements option has the following buttons:
Elements |
Opens the Element Selector panel and allows you to pick the underlying beam, pipe or truss elements from the graphic area. The selected elements are highlighted. The corresponding Reset button resets the selected elements. |
Add |
Adds the selected elements to the current surface and creates special contactsurface elements for display. By default, SPOS faces are created. In order to create SNEG faces, activate the Reverse check box and click Add.
3D Shell, Membrane, or Rigid Elements
2D Solid, Axisymmetric, or Gasket Elements
Element Based Surface: Define Tab
