Define the data for constraint screening. |
Create constraints for optimization problems. |
Create user-defined functions for constraints and/or objective functions. |
Link a design variable to other design variables. |
Define a discrete design variable value table for use in size or shape optimization. |
define design domains for free shape optimization |
define design domains for free size optimization |
Create a single design variable (DESVAR) and multiple property relation (DVPREL1) cards for the components selected for size optimization. |
Access HyperMorph to modify the shape of part meshes. |
Define objective functions for optimization problems. |
Define a response and its reference values for a minmax (maxmin) optimization problem. |
Control the optimization process. |
Setup shape optimization. |
Create responses for an optimization. |
Perform shape optimization. |
Setup and perform size optimization. |
Specify values for the constraints used in defining functions. |
Setup and define topography optimizations. |
Setup and define topology optimizations. |
