Engineering Solutions
CFD Interface Overview
Engineering Solutions includes an application customized for CFD meshing, CFD shape optimization and other CFD tasks such as loads mapping. Native I/O support for AcuSolve, AFLR3, CFD++, CFX, FLUENT, and StarCD is available in the CFD application. Many other CFD solvers are supported through the CGNS format and the extended Nastran format (for pyramids).
When you load the CFD application, the Utility tab contains many utilities for CFD meshing and associated tasks. The Utility tab contains two CFD specific sections: CFD Mesh and CFD I/O. Engineering Solutions has the CFD Tetramesh panel. This panel is intended to generate meshes for CFD applications. Typical meshes are of mixed type, and contain a combination of hexahedra, wedges/prisms/pentas, pyramids, and tetrahedral cells/elements.
See Also:
Tips for StarCD
Tips for FLUENT
Tips for CFX
Tips for CFD Model Export
Multi-Domain Models Tips for FLUENT
Multi-Domain Models Tips for AcuSolve
CFD Utility Menu
Export/Import for CFD Solvers
Plane 2D Meshing from Edges
CFD Meshing in HyperMesh
HyperView User's Guide
HyperView Streamlines Panel
Tutorials
CFD-1000: Creating a Hybrid Grid using the CFD Mesh Panel
CFD-1100: Creating a Hybrid Grid with Varying Boundary Layer Thickness
CFD-1200: CFD Meshing with Automatic BL Thickness Reduction
CFD-1300: Plane 2D Meshing with Boundary Layers
CFD-1400: Wind Tunnel Mesh
CFD-1500: Hexcore Meshing with Boundary Layer
CFD-1600: Using Distributed Thickness for Varying Boundary Layer Thickness
CFD-1700: Mapping CFD Results
CFD-1800: Using Engineering Solutions, AcuSolve and HyperView to Perform a CFD Analysis
HS-1570: DOE and Optimization Study Using FLUENT
HS-1545: DOE and Optimization Study with HyperMesh, HyperStudy, and ANSYS CFX
HS-1535: Coupling HyperStudy, Morphing and AcuSolve (HyperStudy Job Launcher)
