Engineering Solutions
Supported Cards by Solver
Previous topic Next topic Expand/collapse all hidden text
hmtoggle_arrow1RADIOSS
/@TFILE
/@TFILE/Keyword2
/ABF
/ACCEL
/ACTIV
/ACTN
/ADMAS
/ADMESH/GLOBAL
/ADMESH/SET
/ADMESH/STATE/SHELL
/ADMESH/STATE/SH3N
/ALE
/ALE/2
/ALE/3
/ALE/4
/ALE/BCS
/ALE/DISP
/ALE/DONEA
/ALE/MAT
/ALE/SPRING
/ALE/STANDARD
/ALE/ZERO
/ALESUB
/AMS
/ANALY
/ANIM
/ANIM/BRICK/TENS
/ANIM/BRICK/TENS/STRAIN
/ANIM/BRICK/TENS/STRESS
/ANIM/CUT/1
/ANIM/CUT/2
/ANIM/CUT/3
/ANIM/DT
/ANIM/Eltyp/FORC
/ANIM/Eltyp/Restype
/ANIM/GPS1
/ANIM/GPS2
/ANIM/GZIP
/ANIM/KEEPD
/ANIM/LSENSOR
/ANIM/MASS
/ANIM/MAT
/ANIM/NODA
/ANIM/SENSOR
/ANIM/SHELL/EPSP
/ANIM/SHELL/PHI/ALL
/ANIM/SHELL/PHI/N
/ANIM/SHELL/TENS
/ANIM/SHELL/USRi
/ANIM/VECT
/ANIM/VECT/FREAC
/ANIM/VERS
/ARCH
/ATFILE
/BCS
/BCS/ALE
/BCS/LAG
/BCS/ROT
/BCS/TRA
/BCSR/ALE
/BCSR/LAG
/BCSR/ROT
/BCSR/TRA
/BEAM
/BEGIN
/BRIC20
/BRICK
/CAA
/CLOAD
/CNODE
/CONVEC
/CYL_JOINT
/DAMP
/DEF_SHELL
/DEF_SOLID
/DEL
/DEL/Eltyp/1
/DEL/INTER
/DELINT
/DFS/DETLINE
/DFS/DETPOIN
/DFS/LASER
/DFS/WAV_SHA
/DT
/DT/AMS
/DT/Eltyp/Iflag
/DT/Eltyp/Keyword3/Iflag
/DT/NODA/Keyword3
/DT/SHELL
/DT/SHNOD or /DT/SHNOD/CST
/DT/SPHCEL
/DT/SPHCEL/Keyword3
/DT/THERM
/DT1/SHELL
/DTIX
/DTSDE
/DYREL
/DYREL/1
/EBCS
/END/ENGINE
/EOS_GRUNEISEN
/EOS/PUFF
/EOS_POLYNOMIAL
/EOS/SESAME
/EOS_TILLOTSON
/FAIL
/FAIL/CHANG
/FAIL/CONNECT
/FAIL/ENERGY
/FAIL/FLD
/FAIL/HASHIN
/FAIL/JOHNSON
/FAIL/LAD_DAM
/FAIL/PUCK
/FAIL/SPALLING
/FAIL/TAB1
/FAIL/TBUTCHER
/FAIL/TENSSTRAIN
/FAIL/USER1, FAIL/USER2 OR /FAIL/USER3
/FAIL/WIERZBICKI
/FAIL/WILKINS
/FAIL/XFEM
/FRAME/FIX
/FRAME/MOV
/FRAME/MOV2
/FRAME/NOD
/FUNCT
/FVMBAG/MODIF
/FXINP
/GAUGE
/GLOBAL/INT_EXPR/
/GLOBAL/INTEGER/
/GLOBAL/REAL/
/GLOBAL/REAL_EXPR/
/GRAV
/GRBEAM
/GRBEAM/BOX
/GRBEAM/BOX2
/GRBEAM/BEAM
/GRBEAM/GRBEAM
/GRBEAM/MAT
/GRBEAM/PART
/GRBEAM/PROP
/GRBEAM/SUBSET
/GRBRIC
/GRBRIC/BOX
/GRBRIC/BOX2
/GRBRIC/BRIC
/GRBRIC/GRBRIC
/GRBRIC/MAT
/GRBRIC/PART
/GRBRIC/PROP
/GRBRIC/SUBSET
/GRNOD
/GRNOD/BOX
/GRNOD/GENE
/GRNOD/GRBEAM
/GRNOD/GRBRIC
/GRNOD/GRQUAD
/GRNOD/GRSH3N
/GRNOD/GRSHEL
/GRNOD/GRSPRI
/GRNOD/GRTRUS
/GRNOD/MAT
/GRNOD/NODE
/GRNOD/NODENS
/GRNOD/PART
/GRNOD/PROP
/GRNOD/SUBSET
/GRNOD/SURF
/GRPART
/GRQUAD
/GRQUAD/BOX
/GRQUAD/BOX2
/GRQUAD/GRQUAD
/GRQUAD/QUAD
/GRQUAD/MAT
/GRQUAD/PART
/GRQUAD/PROP
/GRQUAD/SUBSET
/GRSH3N
/GRSH3N/BOX
/GRSH3N/BOX2
/GRSH3N/GRSH3N
/GRSH3N/MAT
/GRSH3N/PART
/GRSH3N/PROP
/GRSH3N/SH3N
/GRSH3N/SUBSET
/GRSHEL
/GRSHEL/BOX
/GRSHEL/BOX2
/GRSHEL/GRSHEL
/GRSHEL/MAT
/GRSHEL/PART
/GRSHEL/PROP
/GRSHEL/SHEL
/GRSHEL/SUBSET
/GRSPRI
/GRSPRI/BOX
/GRSPRI/BOX2
/GRSPRI/GRSPRI
/GRSPRI/PART
/GRSPRI/PROP
/GRSPRI/SPRI
/GRSPRI/SUBSET
/GRTRUS
/GRTRUS/BOX
/GRTRUS/BOX2
/GRTRUS/GRTRUS
/GRTRUS/MAT
/GRTRUS/PART
/GRTRUS/PROP
/GRTRUS/SUBSET
/GRTRUS/TRUS
/HEAT/MAT
/IMPACC
/IMPDISP
/IMPL
/IMPL/AUTOSPC
/IMPL/BUCKL/1
/IMPL/BUCKL/2
/IMPL/CHECK
/IMPL/DIVERG/n
/IMPL/DT/1
/IMPL/DT/2
/IMPL/DT/3
/IMPL/DT/FIXPOINT
/IMPL/DT/STOP
/IMPL/DTINI
/IMPL/DYNA/DAMP
/IMPL/DYNA/FSI
/IMPL/DYNA/1
/IMPL/DYNA/2
/IMPL/GSTIF/OFF
/IMPL/INTER/KCOMP
/IMPL/INTER/KNONL
/IMPL/LBFGS/L
/IMPL/LINEAR
/IMPL/LINEAR/INTER
/IMPL/LRIGROT
/IMPL/LSEARCH/n
/IMPL/LSEARCH/OFF
/IMPL/MONVOL/OFF
/IMPL/NCYCLE/STOP
/IMPL/NONLIN
/IMPL/NONLIN/SMDISP
/IMPL/PREPAT
/IMPL/PRINT/LINEAR
/IMPL/PRINT/NONLIN
/IMPL/PSTIF/OFF
/IMPL/QSTAT
/IMPL/QSTAT/DTSCAL
/IMPL/RREF/INTERF/n
/IMPL/RREF/LIMIT
/IMPL/RREF/OFF
/IMPL/SBCS/MSGLV
/IMPL/SBCS/ORDER
/IMPL/SBCS/OUTCORE
/IMPL/SHPOFF
/IMPL/SHPON
/IMPL/SINIT
/IMPL/SOLVER
/IMPL/SPRING
/IMPL/SPRBACK
/IMPLICIT
/IMPTEMP
/IMPVEL
INICONT
/INCMP
/INIBRI/STRA_F
/INIBRI/STRA_FGLO
/INIBRI/STRESS
/INIBRI/STRS_F
/INIBRI/STRS_FGLO
/INISH3/AUX
/INISH3/EPSP
/INISH3/EPSP_F
/INISH3/OTHRO
/INISH3/OTHRO_LOC
/INISH3/STRA_F
/INISH3/STRS_F
/INISH3/STRS_F/GLOBAL
/INISH3/THICK
/INISHE/AUX
/INISHE/EPSP
/INISHE/EPSP_F
/INISHE/OTHRO
/INISHE/OTHRO_LOC
/INISHE/STRA_F
/INISHE/STRS_F
/INISHE/STRS_F/GLOBAL
/INISHE/THICK
/INISTA
/INITEMP
/INITHICK/V5
/INIVEL
/INIVEL/AXIS
/INIV/AXIS/Keyword3
/INIV/AXIS/Keyword3/1
/INIV/ROT
/INIV/ROT/Keyword3/1
/INIV/TRA
/INIV/TRA/Keyword3/1
INIVOL
/INTER
/INTER/LAGMUL/TYPE7
/INTER/TYPE1
/INTER/TYPE2
/INTER/TYPE3
/INTER/TYPE5
/INTER/TYPE6
/INTER/TYPE7
/INTER/TYPE8
/INTER/TYPE9
/INTER/TYPE10
/INTER/TYPE11
/INTER/TYPE12
/INTER/TYPE14
/INTER/TYPE15
/INTER/TYPE18
/INTER/TYPE19
/INTER/TYPE20
/INTER/TYPE21
/INTER/TYPE23
/IOFLAG
/KEREL
/KEREL/1
/KILL
/LEAK/MAT
/LINE
/LINE/BOX
/LINE/BOX2
/LINE/EDGE
/LINE/GRBEAM
/LINE/GRTRUS
/LINE/MAT
/LINE/PROP
/LINE/SEG
/LINE/SURF
/LOAD/CENTRI
/LOAD/PFLUID
/MADYMO
/MAT
/MAT/B-K-EPS
/MAT/BARLAT3
/MAT/BIMAT
/MAT/BIPHAS
/MAT/BOLTZMAN
/MAT/BOUND
/MAT/CHANG
/MAT/COMPSH
/MAT/COMPSO
/MAT/CONC
/MAT/CONNECT
/MAT/COSSER
/MAT/COWPER
/MAT/DAMA
/MAT/DPRAG
/MAT/DPRAG1
/MAT/ELAST
/MAT/ELASTOMER
/MAT/FABR_A
/MAT/FABRI
/MAT/FOAM_PLAS
/MAT/FOAM_TAB
/MAT/FOAM_VISC
/MAT/GAS
/MAT/GRAY
/MAT/GURSON
/MAT/HANSEL
/MAT/HILL
/MAT/HILL_MMC
/MAT/HILL_TAB
/MAT/HONEYCOMB
/MAT/HYD_JCOOK
/MAT/HYD_VISC
/MAT/HYDPLA
/MAT/HYDRO
/MAT/JWL
/MAT/K-EPS
/MAT/KELVINMAX
/MAT/LAW10
/MAT/LAW23
/MAT/LAW50
/MAT/LAW51
/MAT/LAW53
/MAT/LAW54
/MAT/LAW62
/MAT/LAW63
/MAT/LAW65
/MAT/LAW66
/MAT/LAW69
/MAT/LAW74
/MAT/LAW75
/MAT/LAW77
/MAT/LAW78
/MAT/LAW79
/MAT/LAW80
/MAT/LAW81
/MAT/LAW82
/MAT/LAW83
/MAT/LEE_T
/MAT/LES_FLUID
/MAT/OGDEN
/MAT/PLAS_BRIT
/MAT/PLAS_DAMA
/MAT/PLAS_JOHNS
/MAT/PLAS_TAB
/MAT/PLAS_T3
/MAT/PLAS_ZERIL
/MAT/RIGID
/MAT/SAMP
/MAT/STEINB
/MAT/THERM
/MAT/TSAI_TAB
/MAT/UGINE_ALZ
/MAT/USERij
/MAT/VISC_TAB
/MAT/VOID
/MAT/ZERIL
/MAT/ZHAO
/MEMORY
/MON
/MONVOL
/MONVOL/AIRBAG1
/MONVOL/AREA
/MONVOL/COMMU1
/MONVOL/FVMBAG1
/MONVOL/GAS
/MONVOL/PRES
/MOVE_FUNC
/NODE
/OUTP
/OUTP/LSENSOR
/PARITH
/PART
/PLOAD
/PRINT
/PROP
/PROP/BEAM
/PROP/CONNECT
/PROP/FLUID
/PROP/INJECT1
/PROP/INJECT2
/PROP/INT_BEAM
/PROP/KJOINT
/PROP/KJOINT2
/PROP/PLY
/PROP/POROUS
/PROP/RIVET
/PROP/SHELL
/PROP/SH_COMP
/PROP/SH_FABR
/PROP/SH_ORTH
/PROP/SH_PLY
/PROP/SH_SANDW
/PROP/STACK
/PROP/SOLID
/PROP/SOL_ORTH
/PROP/SPH
/PROP/SPR_TAB
/PROP/SPRING
/PROP/SPR_BEAM
/PROP/SPR_GENE
/PROP/SPR_PRE
/PROP/SPR_PUL
/PROP/TRUSS
/PROP/TSHELL
/PROP/TSH_ORTHO
/PROP/TYPE0
/PROP/TYPE6
/PROP/USER
/QUAD
/RADIATION
/RAD2RAD/ON
/RANDOM
/RBE2
/RBE3
/RBODY
/REFSTA
/RERUN
/RFILE
/RFILE/n
/RLINK
/RUN
/RUN/Run Name/Run Number/Restart Letter
/RWALL/THERM
/SECT
/SENSOR
/SENSOR/ACCE
/SENSOR/AND
/SENSOR/DIST
/SENSOR/GAUGE
/SENSOR/INTER
/SENSOR/NOT
/SENSOR/OR
/SENSOR/RBODY
/SENSOR/RWAL/
/SENSOR/SECT
/SENSOR/SENS
/SENSOR/TIME
/SH3N
/SHELL
/SHSUB
/SHVER/V51
/SKEW/MOV
/SKEW/MOV2
/SPHBCS
/SPHCEL
/SPHGLO
/SPH/INOUT
/SPH/RESERVE
/SPMD
/SPRING
/STAMPING
/STATE/BRICK/AUX/FULL
/STATE/BRICK/ORTHO
/STATE/BRICK/STAIN/FULL
/STATE/BRICK/STRAIN/GLOBFULL
/STATE/BRICK/STRES/FULL
/STATE/BRICK/STRESS/GLOBFULL
/STATE/DT
/STATE/NODE/TEMP
/STATE/LSENSOR
/STATE/SHELL/AUX/FULL
/STATE/SHELL/EPSP/FULL
/STATE/SHELL/ORTHL
/STATE/SHELL/STRAIN/FULL
/STATE/SHELL/STRESS/FULL
/STATE/STR_FILE
/STOP
/SUBSET
/SURF
/SURF/BOX
/SURF/BOX2
/SURF/BOX/ALL
/SURF/BOX/EXT
/SURF/GRSHELL
/SURF/MAT
/SURF/MAT/ALL
/SURF/MAT/EXT
/SURF/PART
/SURF/PART/ALL
/SURF/PART/EXT
/SURF/PROP
/SURF/PROP/ALL
/SURF/PROP/EXT
/SURF/SEG
/SURF/SRSH3N
/SURF/SUBSET
/SURF/SUBSET/ALL
/SURF/SUBSET/EXT
/SURF/SURF
/TABLE
/TETRA4
/TETRA10
/TFILE
/TH/ACCEL/
/TH/BEAM/
/TH/BRIC/
/TH/CYL_JO/
/TH/FRAME/
/TH/GAUGE
/TH/INTER/
/TH/MONV/
/TH/NODE/
/TH/QUAD/
/TH/PART/
/TH/RBODY/
/TH/RWALL/
/TH/SECTIO/
/TH/SH3N/
/TH/SHEL/
/TH/SPHCEL/
/TH/SPRING/
/TH/SUBS
/TH/TRUSS/
/TH/VERS
/THERM_STRESS/MAT
/TITLE
/TRANSFORM/ROT
/TRANSFORM/SCA
/TRANSFORM/SYM
/TRANSFORM/TRA
/TRUSS
/UNIT
/UPWIND
/UPWM/SUPG
/UPWM/TG
/VEL/ALE
/VEL/ROT
/VEL/TRA
/VERS
/VISC_PRONEY
hmtoggle_arrow1OptiStruct
ACCELERATION
ACCLR
ACMODL
ACSRCE
ANALYSIS
ASET
ASET1
ASSIGN
AUTOSPC
B2GG
BMFACE
BORE
CAABSF
CAALOAD
CBAR
CBEAM
CBUSH
CBUSH1D
CDAMP1
CDAMP2
CDAMP3
CDAMP4
CDSMETH
CELAS1
CELAS2
CELAS3
CELAS4
CFAST
CGAP
CGAPG
CGASK6
CGASK8
CGASK12
CGASK16
CHACAB
CHBDYE
CHECK
CHEXA (8-noded)
CHEXA (20-noded)
CMASS1
CMASS2
CMASS3
CMASS4
CMBEAM
CMBUSH
CMBUSHC
CMBUSHE
CMBUSHT
CMSMETH
CMSPDP
CMSPDPC
CMSPDPE
CMSPDPT
CNTSTB
CONM1
CONM2
CONROD
CONTACT
CONTF
CONTPRM
CONV
CORD1C
CORD1R
CORD1S
CORD2C
CORD2R
CORD2S
CORD3R
CORD4R
CPENTA (6-noded)
CPENTA (15-noded)
CPYRA (5-noded)
CPYRA (13-noded)
CQUADR
CQUAD4
CQUAD8
CROD
CSHEAR
CSTRAIN
CSTRESS
CTAXI
CTETRA (4-noded)
CTETRA (10-noded)
CTRIAR
CTRIAX6
CTRIA3
CTRIA6
CTUBE
CVISC
CWELD
DAMAGE
DAREA
DCOMP
DCONADD
DCONSTR
DDVAL
DEBUG
DEFORM
DENSITY
DENSRES
DEQATN
DESGLB
DESHIS
DESOBJ
DESSUB
DESVAR
DESVARG
DGLOBAL
DISPLACEMENT
DLINK
DLINK2
DLOAD
DMIGNAME
DOBJREF
DOPTPRM
DPENTA6
DQUAD4
DRESP1
DRESP2
DRESP3
DSCREEN
DSHAPE
DSHUFFLE
DSIZE
DSYSID
DTABLE
DTETRA4
DTI_SPECSEL
DTI_UNITS
DTPG
DTPL
DTRIA3
DVCREL1
DVCREL2
DVGRID
DVMREL1
DVMREL2
DVPREL1
DVPREL2
ECHO
EIGC
EIGRA
EIGRL
EIGVNAME
EIGVRETRIEVE
EIGVSAVE
ELFORCE
ELIST
ENERGY
ERP
ERPPNL
ESE
EXCLUDE
FATDEF
FATEVNT
FATLOAD
FATPARM
FATSEQ
FLLWER
FLUX
FORCE
FORCE1
FORMAT
FREQ
FREQ1
FREQ2
FREQ3
FREQ4
FREQ5
FREQUENCY
FSI
GAPPRM
GLOBAL_CASE_CONTROL
GLOBSUB
GPFORCE
GPSTRAIN
GPSTRESS
GRAV
GRDSET
GRID
GROUND
HISOUT
HM_ELAS
HMSPRING
HYBDAMP
IC
INCLUDE_BULK
INCLUDE_CTRL
INFILE
INVEL
INVELB
JOINT
K2GG
K2PP
K42GG
LABEL
LIFE
LOAD
LOADLIB
M2GG
MARKER
MAT1
MAT2
MAT3
MAT4
MAT5
MAT8
MAT9
MAT9ORT
MAT10
MATFAT
MATF1
MATF2
MATF8
MATF9
MATF10
MATHE
MATPE1
MATS1
MATT1
MATT2
MATT4
MATT5
MATT8
MATT9
MATX02
MATX13
MATX27
MATX33
MATX36
MATX42
MATX44
MATX62
MATX65
MATX70
MATX82
MBACT
MBCNTDS
MBCNTR
MBCRV
MBDCRV
MBDEACT
MBDSRF
MBFORCE
MBFRC
MBFRCC
MBLIN
MBMNT
MBMNTC
MBPCRV
MBREQ
MBREQE
MBREQM
MBSEQ
MBSIM
MBSIMP
MBVAR
METHOD
MGASK
MFLUID
MINMAX
MLOAD
MODEL
MODEWEIGHT
MOMENT
MOMENT1
MOTION
MOTNG
MOTNGC
MPC
MPCADD
MPCFORCE
MPCFORCES
MSGLMT
NESLEXPD
NESLIMPD
NESLNLGM
NLADAPT
NLOAD (Constraint Load)
NLOAD (Case Control)
NLOAD1
NLOUT
NLPARM
NLPARMX
NSM (Global Case Control Card)
NSMADD
NSM1
NSML1
OFREQUENCY
OLOAD
OMODES
OSDIAG
OTIME
OUTFILE
OUTPUT
P2G
PAABSF
PACABS
PANEL
PANELG
PARAM
PAXI
PBAR
PBARL
PBEAM
PBEAML
PBUSH
PBUSH1D
PCOMP
PCOMPG
PCOMPP
PCONT
PCONTX
PDAMP
PEAKOUT (Control Card)
PEAKOUT (Load Collector)
PELAS
PFAST
PFAT
PFBODY
PFGRID
PFMODE
PFPANEL
PFPATH
PGAP
PGASK
PLOAD
PLOAD1
PLOAD2
PLOAD4
PLOTEL
PLOTEL3
PLOTEL4
PLY
PMASS
PRBODY
PRESSURE
PROD
PROPERTY
PSHEAR
PSHELL
PSOLID
PTADD
PTUBE
PVISC
PWELD
QBDY1
QVOL
RANDPS
RBAR
RBE2
RBE3
REQUEST
RESPRINT
RESTART
RESULTS
RESVEC
RFORCE
RGYRO
RLOAD1
RLOAD2
ROTORG
RROD
RSPEC
RSPEC (Case Control)
RSPEED
RSPINR
RWALL (Group)
RWALL (Case Control)
RWALLADD
SCREEN
SDAMPING
SECT
SENSITIVITY
SENSOUT
SET
SET3
SHAPE
SHAPEOPT
SHRES
SOLVTYP
SPC
SPCADD
SPCD
SPCFORCES
SPOINT
STACK
STATSUB
STRAIN
STRESS
SUBCASE
SUBCOM
SUBMODEL
SUBSEQ
SUBTITLE
SUPORT
SUPORT1
SURF
SWLDPRM
SYSSETTING
TABDMP1
TABFAT
TABLED1
TABLED2
TABLED3
TABLED4
TABLEFAT
TABLEM1
TABLEM2
TABLEM3
TABLEM4
TABLES1
TABLEST
TABRND1
TEMP
TEMPD
THERMAL
THICKNESS
THIN
TIC
TICA
TIE
TITLE
TLOAD1
TLOAD2
TMPDIR
TSTEP
TSTEPNL
TSTEPNX
TTERM
UNBALNC
UNITS
USET
USET1
VELOCITY
WEIGHT
XDAMP
XHIST (Output Block)
XHIST (Case Control)
XHISTADD
XSHLPRM
XSOLPRM
XSTEP (Load Collector)
hmtoggle_arrow1Abaqus
To create Abaqus cards, load the Abaqus user profile and select the appropriate template (Standard.2d, Standard.3d, or Explicit).
The supported Abaqus cards:
*AMPLITUDE
*BEAM ADDED INERTIA
*BEAM GENERAL SECTION
*BEAM SECTION
*BIAXIAL TEST DATA
*BLOCKAGE
*BOUNDARY
*BUCKLE
*BULK VISCOSITY
*CECHARGE
*CECURRENT
*CFILM
*CFLUX
*CHANGE FRICTION
*CLEARANCE
*CLOAD
*COHESIVE BEHAVIOR
*COHESIVE SECTION
*COMBINED TEST DATA
*CONDUCTIVITY
*CONNECTOR BEHAVIOR
*CONNECTOR CONSTITUTIVE REFERENCE
*CONNECTOR CONTACT FORCE
*CONNECTOR DAMPING
*CONNECTOR ELASTICITY
*CONNECTOR FAILURE
*CONNECTOR FRICTION
*CONNECTOR HARDENING
*CONNECTOR LOAD
*CONNECTOR LOCK
*CONNECTOR MOTION
*CONNECTOR PLASTICITY
*CONNECTOR SECTION
*CONNECTOR STOP
*CONSTRAINT CONTROLS
*CONTACT (General Contact)
*CONTACT CLEARANCE
*CONTACT CLEARANCE ASSIGNMENT
*CONTACT CONTROLS
*CONTACT CONTROLS ASSIGNMENT
*CONTACT DAMPING (Explicit template)
*CONTACT DAMPING (Standard templates)
*CONTACT EXCLUSIONS
*CONTACT FILE
*CONTACT FORMULATION
*CONTACT INCLUSIONS
*CONTACT INTERFERENCE
*CONTACT OUTPUT
*CONTACT PAIR
*CONTACT PRINT
*CONTACT PROPERTY ASSIGNMENT
*CONTACT PROPERTY ASSIGNMENT, PROPERTY=OFFSET FRACTION
*CONTACT PROPERTY ASSIGNMENT, PROPERTY=THICKNESS
*CONTROLS
*COUPLED TEMP-DISPLACEMENT
*COUPLING
*CREEP
*CRUSHABLE FOAM
*CRUSHABLE FOAM HARDENING
*DAMPING
*DASHPOT
*DEBOND
*DECHARGE
*DENSITY
*DEPVAR
*DFLUX
*DIAGNOSTICS
*DIELECTRIC
*DISTRIBUTING
*DISTRIBUTING COUPLING
*DISTRIBUTION
*DISTRIBUTION_ANGLE
*DISTRIBUTION_DRAPE
*DISTRIBUTION_OFFSET
*DISTRIBUTION_ORIENTATION
*DISTRIBUTION_THICKNESS
*DLOAD
*DSLOAD
*DYNAMIC
*DYNAMIC (Explicit)
*EL FILE
*EL PRINT
*ELASTIC
*ELEMENT
*ELEMENT OUTPUT
*ELEMENT PROPERTIES
*ELGEN
*ELSET
*EMBEDDED ELEMENT
*ENERGY FILE
*ENERGY OUTPUT
*ENERGY PRINT
*EQUATION
*EULERIAN SECTION
*EXPANSION
*FASTENER (SPOT WELD)
*FASTENER PROPERTY
*FILE FORMAT
*FILM
*FILTER
*FIXED MASS SCALING
*FLUID BEHAVIOR
*FLUID BULK
*FLUID DENSITY
*FLUID EXPANSION
*FLUID PROPERTY
*FRACTURE CRITERION
*FREQUENCY
*FRICTION (Explicit template)
*FRICTION (Standard templates)
*GAP
*GASKET BEHAVIOR
*GASKET CONTACT AREA
*GASKET ELASTICITY
*GASKET SECTION
*GASKET THICKNESS BEHAVIOR
*HEADING
*HEAT TRANSFER
*HYPERELASTIC
*HYPERFOAM
*INCREMENTATION OUTPUT
*INERTIA RELIEF
*INITIAL CONDITION (TYPE=STRESS)
*INITIAL CONDITION (TYPE=PRESSURE)
*INITIAL CONDITION (TYPE=TEMPERATURE)
*INITIAL CONDITION (TYPE=VELOCITY)
*INTEGRATED OUTPUT
*INTEGRATED OUTPUT SECTION
*JOINT
*KINEMATIC
*KINEMATIC COUPLING
*LOAD CASE
*MASS
*MATERIAL
*MEMBRANE SECTION
*MODAL_DAMPING
*MODAL DYNAMIC
*MODAL OUTPUT
*MODEL CHANGE
*MONITOR
*MPC
*MULLINS EFFECT
*NODAL THICKNESS
*NFILL
*NGEN
*NMAP
*NODE
*NODE FILE
*NODE OUTPUT
*NODE PRINT
*NONSTRUCTURAL MASS
*NSET
*ORIENTATION
*OUTPUT
*PARAMETER
*PHYSICAL CONSTANT
*PIEZOELECTRIC
*PLANAR TEST DATA
*PLASTIC
*PREPRINT
*PRE-TENSION SECTION
*PRINT
*RADIATE
*RADIATION VIEWFACTOR
*RATE DEPENDENT
*REBAR LAYER
*RELEASE
*RESPONSE SPECTRUM
*RESTART
*RESTART
*RIGID BODY
*ROTARY INERTIA
*SECTION CONTROLS
*SFILM
*SHEAR FAILURE
*SHEAR TEST DATA
*SHELL GENERAL SECTION
*SHELL SECTION
*SHELL TO SOLID COUPLING
*SIMPLE SHEAR TEST DATA
*SOLID SECTION
*SPECIFIC HEAT
*SPECTRUM
*SPRING
*STATIC
*STEADY STATE DYNAMICS
*STEP
*SURFACE
*SURFACE BEHAVIOR (Explicit template)
*SURFACE BEHAVIOR (Standard templates)
*SURFACE INTERACTION (Explicit template)
*SURFACE INTERACTION (Standard templates)
*SURFACE PROPERTY/*EMISSIVITY
*SURFACE PROPERTY ASSIGNMENT (Explicit template)
*SURFACE SECTION
*SURFACE SMOOTHING
*SYSTEM
*TEMPERATURE
*TIE
*TRANSFORM
*TRANSVERSE SHEAR STIFFNESS
*UNIAXIAL TEST DATA
*USER MATERIAL
*USER OUTPUT VARIABLES
*VARIABLE MASS SCALING
*VISCO
*VISCOELASTIC
*VOLUMETRIC TEST DATA
hmtoggle_arrow1ANSYS
The input translator recognizes the ANSYS cards listed below.  If an unsupported field is found in a card, a message is displayed on the status bar.  The messages are also printed to the file ansys.msg.  General slash commands, SOLUTION commands, POST1 commands, and POST26 commands are referred to as control cards.  Unrecognized cards are written to a *.hmx file.
ACEL
ALPHAD
ANTYPE
ARCLEN
ARCTRM
/ASSIGN
AUTOTS
/BATCH
BEAM3
BEAM4
BEAM23
BEAM24
BEAM44
BEAM54
BEAM188
BEAM189
BETAD
/BFUNIF
BF
BF_FLUE
BF_HGEN
BF_TEMP
BFE_FLUE
BFE_HGEN
BFE_TEMP
BUCOPT
CE
CERIG
CGLOC
CGOMGA
CIRCU124
CMACEL
CMDOMEGA
CMOMEGA
CMGRP
CNVTOL
/COM
COMBIN14
COMBIN39
COMBIN40
CONTA171
CONTA172
CONTA173
CONTA174
CONTA175
CONTA177
CONTA178
CONTAC12
CONTAC48
CONTAC49
CONTAC52
ConvBulkTe
ConvFilmCo
/COPY
CP_ELEC
CP_STRUC
CRPLIM
D_CONSTRNT
D_TEMP
D_VOLT
DCGOMG
/DELETE
DELTIM
DIM
DMPRAT
DOF
DOMEGA
EMUNIT
EQSLV
ERESX
EORIENT
ETABLE
EXPASS
F_FLOW
F_HEAT
FLOTRAN
FLUID
FLUID29
FLUID30
FLUID80
FLUID116
FORCE
FORCE2
HARFRQ
HF118
HF119
HF120
HFLUX
HM_COMP
HREXP
HROPT
HROUT
HYPER58
IC_CONSTRN
IC_TEMP
IC_VOLT
INFIN9
INFIN110
INTER192
INTER193
INTER194
INTER195
IRLF
KBC
KUSE
LINK1
LINK8
LINK10
LINK31
LINK32
LINK33
LINK34
LINK68
LINK180
LNSRCH
LOCAL
LSSOLVE
LVSCALE
MASS21
MASS71
MAT
MATRIX27
MDAMP\
MESH200
MODE
MODOPT
MP
MPDATA
MPC184
MPTEMP
MXPAND
N
NBLOCK
NCNV
NEQIT
NLGEOM
NROPT
NSUBST
OMEGA
OUTRES
PIPE16
PIPE18
PIPE20
PIPE60
PLANE2
PLANE13
PLANE25
PLANE35
PLANE42
PLANE53
PLANE55
PLANE67
PLANE75
PLANE77
PLANE78
PLANE82
PLANE83
PLANE121
PLANE145
PLANE146
PLANE162
PLANE182
PLANE183
PLANE223
/POST1
PRED
PRESOL
PRESSURE
PRETS179
PSTRES
RBE3
RSYS
SECCONTROLS
SECDATA
SECOFFSET
SECTYPE
SFE
SHELL28
SHELL41
SHELL43
SHELL51
SHELL57
SHELL61
SHELL63
SHELL91
SHELL93
SHELL99
SHELL131
SHELL132
SHELL143
SHELL150
SHELL157
SHELL163
SHELL181
SHELL208
SHELL209
SHELL281
SLOAD
SOLID5
SOLID45
SOLID46
SOLID62
SOLID64
SOLID69
SOLID70
SOLID72
SOLID73
SOLID87
SOLID90
SOLID92
SOLID95
SOLID96
SOLID97
SOLID98
SOLID117
SOLID147
SOLID148
SOLID164
SOLID168
SOLID185
SOLID186
SOLID187
SOLID191
SOLID226
SOLID227
SOLSH190
/SOLU
SOLU
SOLVE
SSTIF
/STITLE
SUBOPT
SURF151
SURF152
SURF153
SURF154
SURF156
SURF251
SURF252
/SYS
TARGE169
TARGE170
TB
TBDATA
TIME
TIMINT
TINTP
/TITLE
TOFFST
TOTAL
TREF
TRNOPT
TUNIF
/UNITS
VISCO88
VISCO107
Note:One component collector is created for every unique combination of Type, Real, Mat, and SECNUM. Surface loads on 1D elements is not supported. Property collectors are created for each real set defined in the ANSYS deck. Material collectors are also created for each material ID encountered.  The component in HyperMesh is different from the component (CM) in ANSYS.
hmtoggle_arrow1LS-DYNA
The following cards are supported by LS-DYNA:
*AIRBAG_ADIABATIC_GAS_MODEL_ID
*AIRBAG_ALE
*AIRBAG_ADVANCED_ALE
*AIRBAG_HYBRID_CHEMKIN_ID
*AIRBAG_HYBRID_ID
*AIRBAG_HYBRID_JETTING_CM_ID
*AIRBAG_HYBRID_JETTING_ID
*AIRBAG_INTERACTION_ID
*AIRBAG_LINEAR_FLUID_ID
*AIRBAG_LOAD_CURVE_ID
*AIRBAG_PARTICLE
*AIRBAG_REFERENCE_GEOMETRY_BIRTH
*AIRBAG_REFERENCE_GEOMETRY_BIRTH_RDT
*AIRBAG_REFERENCE_GEOMETRY_RDT
*AIRBAG_SIMPLE_AIRBAG_MODEL_ID
*AIRBAG_SIMPLE_PRESSURE_VOLUME_ID
*AIRBAG_WANG_NEFSKE_ID
*AIRBAG_WANG_NEFSKE_JETTING_ID
*AIRBAG_WANG_NEFSKE_JETTING_CM
*AIRBAG_WANG_NEFSKE_JETTING_POP_ID
*AIRBAG_WANG_NEFSKE_JETTING_POP_CM
*AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_CM_ID
*AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_ID
*AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_POP_CM
*AIRBAG_WANG_NEFSKE_MULTIPLE_JETTING_POP_ID
*AIRBAG_WANG_NEFSKE_POP_ID
*ALE_MULTI_MATERIAL_GROUP
*ALE_REFERENCE_SYSTEM_CURVE
*ALE_REFERENCE_SYSTEM_GROUP
*ALE_REFERENCE_SYSTEM_NODE
*ALE_REFERENCE_SYSTEM_SWITCH
*ALE_SMOOTHING
*ALE_TANK_TEST
*BOUNDARY_AMBIENT_EOS
*BOUNDARY_CONVECTION_SET
*BOUNDARY_FLUX_SET
*BOUNDARY_NON_REFLECTING
*BOUNDARY_NON_REFLECTING_2D
*BOUNDARY_PRESCRIBED_MOTION_NODE
*BOUNDARY_PRESCRIBED_MOTION_NODE_(ID)
*BOUNDARY_PRESCRIBED_MOTION_RIGID
*BOUNDARY_PRESCRIBED_MOTION_RIGID_(ID)
*BOUNDARY_PRESCRIBED_MOTION__RIGID_LOCAL
*BOUNDARY_PRESCRIBED_MOTION__RIGID_LOCAL_(ID)
*BOUNDARY_PRESCRIBED_MOTION_SET
*BOUNDARY_PRESCRIBED_MOTION_SET_(ID)
*BOUNDARY_RADIATION_SET
*BOUNDARY_SPC_NODE_(ID)
*BOUNDARY_SPC_SET
*BOUNDARY_SPC_SET_(ID)
*BOUNDARY_SPH_FLOW
*BOUNDARY_TEMPERATURE_NODE
*BOUNDARY_TEMPERATURE_SET
*CONSTRAINED_EXTRA_NODES_NODE
*CONSTRAINED_EXTRA_NODES_SET
*CONSTRAINED_GENERALIZED_WELD_BUTT_(ID)
*CONSTRAINED_GENERALIZED_WELD_COMBINED_(ID)
*CONSTRAINED_GENERALIZED_WELD_CROSS_FILLET_(ID)
*CONSTRAINED_GENERALIZED_WELD_FILLET_(ID)
*CONSTRAINED_GENERALIZED_WELD_SPOT_(ID)
*CONSTRAINED_GLOBAL
*CONSTRAINED_INTERPOLATION
*CONSTRAINED_JOINT_CONSTANT_VELOCITY
*CONSTRAINED_JOINT_CYLINDRICAL
*CONSTRAINED_JOINT_CYLINDRICAL_FAILURE(ID)
*CONSTRAINED_JOINT_CYLINDRICAL_LOCAL(ID)
*CONSTRAINED_JOINT_CYLINDRICAL_LOCAL_FAILURE(ID)
*CONSTRAINED_JOINT_GEARS
*CONSTRAINED_JOINT_LOCKING(ID)
*CONSTRAINED_JOINT_LOCKING_FAILURE(ID)
*CONSTRAINED_JOINT_LOCKING_LOCAL(ID)
*CONSTRAINED_JOINT_LOCKING_LOCAL_FAILURE(ID)
*CONSTRAINED_JOINT_PLANAR(ID)
*CONSTRAINED_JOINT_PLANAR_FAILURE(ID)
*CONSTRAINED_JOINT_PLANAR_LOCAL_FAILURE_(ID)
*CONSTRAINED_JOINT_PLANAR_LOCAL(ID)
*CONSTRAINED_JOINT_PULLEY
*CONSTRAINED_JOINT_RACK_AND_PINION
*CONSTRAINED_JOINT_REVOLUTE
*CONSTRAINED_JOINT_REVOLUTE_FAILURE(ID)
*CONSTRAINED_JOINT_REVOLUTE_LOCAL(ID)
*CONSTRAINED_JOINT_REVOLUTE_LOCAL_FAILURE(ID)
*CONSTRAINED_JOINT_ROTATIONAL_MOTOR
*CONSTRAINED_JOINT_SCREW
*CONSTRAINED_JOINT_SPHERICAL(ID)
*CONSTRAINED_JOINT_SPHERICAL_LOCAL(ID)
*CONSTRAINED_JOINT_SPHERICAL_FAILURE(ID)
*CONSTRAINED_JOINT_SPHERICAL_LOCAL_FAILURE(ID)
*CONSTRAINED_JOINT_STIFFNESS_FLEXION-TORSION
*CONSTRAINED_JOINT_STIFFNESS_GENERALIZED
*CONSTRAINED_JOINT_STIFFNESS_TRANSLATIONAL
*CONSTRAINED_JOINT_TRANSLATIONAL(ID)
*CONSTRAINED_JOINT_TRANSLATIONAL_FAILURE(ID)
*CONSTRAINED_JOINT_TRANSLATIONAL_LOCAL(ID)
*CONSTRAINED_JOINT_TRANSLATIONAL_LOCAL_FAILURE(ID)
*CONSTRAINED_JOINT_TRANSLATIONAL_MOTOR
*CONSTRAINED_JOINT_UNIVERSAL(ID)
*CONSTRAINED_JOINT_UNIVERSAL_FAILURE(ID)
*CONSTRAINED_JOINT_UNIVERSAL_LOCAL(ID)
*CONSTRAINED_JOINT_UNIVERSAL_LOCAL_FAILURE(ID)
*CONSTRAINED_LAGRANGE_IN_SOLID
*CONSTRAINED_LINEAR
*CONSTRAINED_LINEAR_GLOBAL
*CONSTRAINED_NODAL_RIGID_BODY
*CONSTRAINED_NODAL_RIGID_BODY (2-Noded)
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA (2-Noded)
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA _SPC
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA _SPC (2-Noded)
*CONSTRAINED_NODAL_RIGID_BODY_SPC
*CONSTRAINED_NODAL_RIGID_BODY_SPC (2-Noded)
*CONSTRAINED_NODE_SET
*CONSTRAINED_NODE_SET (2-Noded)
*CONSTRAINED_NODE_SET_ID
*CONSTRAINED_RIGID_BODIES
*CONSTRAINED_RIGID_BODY_STOPPERS
*CONSTRAINED_RIVET
*CONSTRAINED_SHELL_TO_SOLID
*CONSTRAINED_SPOTWELD_FILTERED_FORCE_ID
*CONSTRAINED_SPOTWELD_ID
*CONSTRAINED_TIE_BREAK
*CONSTRAINED_TIED_NODES_FAILURE
*CONTACT_AIRBAG_SINGLE_SURFACE(ID)
*CONTACT_AIRBAG_SINGLE_SURFACE_MPP(ID)
*CONTACT_AUTO_MOVE
*CONTACT_AUTOMATIC_GENERAL(ID)
*CONTACT_AUTOMATIC_GENERAL_INTERIOR(ID)
*CONTACT_AUTOMATIC_GENERAL_INTERIOR_MPP(ID)
*CONTACT_AUTOMATIC_GENERAL_MPP(ID)
*CONTACT_AUTOMATIC_NODES_TO_SURFACE(ID)
*CONTACT_AUTOMATIC_NODES_TO_SURFACE_MPP(ID)
*CONTACT_AUTOMATIC_NODES_TO_SURFACE_SMOOTH(ID)
*CONTACT_AUTOMATIC_NODES_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE(ID)
*CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK(ID)
*CONTACT_AUTOMATIC_SINGLE_SURFACE(ID)
*CONTACT_AUTOMATIC_SINGLE_SURFACE_MPP(ID)
*CONTACT_AUTOMATIC_SINGLE_SURFACE_SMOOTH(ID)
*CONTACT_AUTOMATIC_SINGLE_SURFACE_SMOOTH_MPP(ID)
*CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_MORTAR_TIED(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_FRICTION(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(ID)
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK_MPP(ID)
*CONTACT_CONSTRAINT_NODES_TO_SURFACES(ID)
*CONTACT_CONSTRAINT_NODES_TO_SURFACE_MPP(ID)
*CONTACT_CONSTRAINT_SURFACE_TO_SURFACE(ID)
*CONTACT_CONSTRAINT_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_DRAWBEAD(ID)
*CONTACT_DRAWBEAD_MPP(ID)
*CONTACT_ENTITY(ID)
*CONTACT_ENTITY_MPP(ID)
*CONTACT_ERODING_NODES_TO_SURFACE(ID)
*CONTACT_ERODING_NODES_TO_SURFACE_MPP(ID)
*CONTACT_ERODING_SINGLE_SURFACE(ID)
*CONTACT_ERODING_SINGLE_SURFACE_MPP(ID)
*CONTACT_ERODING_SURFACE_TO_SURFACE(ID)
*CONTACT_ERODING_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_FORCE_TRANSDUCER_CONSTRAINT(ID)
*CONTACT_FORCE_TRANSDUCER_CONSTRAINT_MPP(ID)
*CONTACT_FORCE_TRANSDUCER_PENALTY(ID)
*CONTACT_FORCE_TRANSDUCER_PENALTY_MPP(ID)
*CONTACT_FORMING_NODES_TO_SURFACE(ID)
*CONTACT_FORMING_NODES_TO_SURFACE_MPP(ID)
*CONTACT_FORMING_NODES_TO_SURFACE_SMOOTH(ID)
*CONTACT_FORMING_NODES_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_MPP(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_SMOOTH(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_SMOOTH_MPP(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_FORMING_ONEWAY_SURFACE_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_SMOOTH(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE_MORTAR(ID)
*CONTACT_FORMING_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_INTERIOR(ID)
*CONTACT_INTERIOR_MPP(ID)
*CONTACT_NODES_TO_SURFACE(ID)
*CONTACT_NODES_TO_SURFACE_INTERFERENCE(ID)
*CONTACT_NODES_TO_SURFACE_INTERFERENCE_MPP(ID)
*CONTACT_NODES_TO_SURFACE_MPP(ID)
*CONTACT_NODES_TO_SURFACE_SMOOTH
*CONTACT_NODES_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_MPP(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_CONSTRAINED_OFFSET(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_INTERFERENCE_CONSTRAINED_OFFSET_MPP(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_ONE_WAY_SURFACE_TO_SURFACE_SMOOTH_MPP(ID)
*CONTACT_RIGID_BODY_ONE_WAY_TO_RIGID_BODY(ID)
*CONTACT_RIGID_BODY_ONE_WAY_TO_RIGID_BODY_MPP(ID)
*CONTACT_RIGID_BODY_TWO_WAY_TO_RIGID_BODY(ID)
*CONTACT_RIGID_BODY_TWO_WAY_TO_RIGID_BODY_MPP(ID)
*CONTACT_RIGID_NODES_TO_RIGID_BODY(ID)
*CONTACT_RIGID_NODES_TO_RIGID_BODY_MPP(ID)
*CONTACT_RIGID_SURFACE(ID)
*CONTACT_RIGID_SURFACE_MPP(ID)
*CONTACT_SINGLE_EDGE(ID)
*CONTACT_SINGLE_EDGE_MPP(ID)
*CONTACT_SINGLE_SURFACE(ID)
*CONTACT_SINGLE_SURFACE_MPP(ID)
*CONTACT_SLIDING_ONLY(ID)
*CONTACT_SLIDING_ONLY_MPP(ID)
*CONTACT_SLIDING_ONLY_PENALTY(ID)
*CONTACT_SLIDING_ONLY_PENALTY_MPP(ID)
*CONTACT_SPOTWELD(ID)
*CONTACT_SPOTWELD_MPP(ID)
*CONTACT_SPOTWELD_WITH_TORSION(ID)
*CONTACT_SPOTWELD_WITH_TORSION_MPP(ID)
*CONTACT_SURFACE_TO_SURFACE(ID)
*CONTACT_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET
*CONTACT_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_MPP
*CONTACT_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_SMOOTH
*CONTACT_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_SMOOTH_MPP
*CONTACT_SURFACE_TO_SURFACE_CONTRACTION_JOINT(ID)
*CONTACT_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_SURFACE_TO_SURFACE_INTERFERENCE(ID)
*CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_MPP(ID)
*CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_CONSTRAINED_OFFSET
*CONTACT_SURFACE_TO_SURFACE_INTERFERENCE_CONSTRAINED_OFFSET_MPP
*CONTACT_SURFACE_TO_SURFACE_SMOOTH(ID)
*CONTACT_SURFACE_TO_SURFACE_THERMAL(ID)
*CONTACT_SURFACE_TO_SURFACE_THERMAL_FICTION(ID)
*CONTACT_SURFACE_TO_SURFACE_THERMAL_MPP(ID)
*CONTACT_TIEBREAK_NODES_TO_SURFACE(ID)
*CONTACT_TIEBREAK_NODES_TO_SURFACE_MPP(ID)
*CONTACT_TIEBREAK_SURFACE_TO_SURFACE(ID)
*CONTACT_TIEBREAK_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_TIED_NODE_TO_SURFACE(ID)
*CONTACT_TIED_NODE_TO_SURFACE_MPP(ID)
*CONTACT_TIED_NODE_TO_SURFACE_CONSTRAINED_OFFSET(ID)
*CONTACT_TIED_NODE_TO_SURFACE_CONSTRAINED_OFFSET_MPP(ID)
*CONTACT_TIED_NODE_TO_SURFACE_OFFSET(ID)
*CONTACT_TIED_NODE_TO_SURFACE_OFFSET_MPP(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFFSET(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_BEAM_OFFSET_MPP(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_CONSTRAINED_OFFSET(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_CONSTRAINED_OFFSET_MPP(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_MPP(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_OFFSET(ID)
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_OFFSET_MPP(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE_CONSTRAINED_OFFSET_MPP(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE_MPP(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE_OFFSET(ID)
*CONTACT_TIED_SURFACE_TO_SURFACE_OFFSET_MPP(ID)
*CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE(ID)
*CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_TITLE(ID)
*CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE_THERMAL_TITLE_MPP(ID)
*CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE_TITLE(ID)
*CONTACT_2D_AUTOMATIC_SURFACE_TO_SURFACE_TITLE_MPP(ID)
*CONTACT_2D_AUTOMATIC_TIED_TITLE
*CONTROL_ACCURACY
*CONTROL_ADAPSTEP
*CONTROL_ADAPTIVE
*CONTROL_ADAPTIVE_CURVE
*CONTROL_ALE
*CONTROL_BULK_VISCOSITY
*CONTROL_CHECK
*CONTROL_COARSEN
*CONTROL_CONTACT
*CONTROL_COUPLING
*CONTROL_CPM
*CONTROL_CPU
*CONTROL_DYNAMIC_RELAXATION
*CONTROL_EFG
*CONTROL_ENERGY
*CONTROL_EXPLOSIVE_SHADOW
*CONTROL_HOURGLASS
*CONTROL_IMPLICIT_AUTO
*CONTROL_IMPLICIT_BUCKLE
*CONTROL_IMPLICIT_DYNAMICS
*CONTROL_IMPLICIT_EIGENVALUE
*CONTROL_IMPLICIT_GENERAL
*CONTROL_IMPLICIT_INERTIA_RELIEF
*CONTROL_IMPLICIT_MODES
*CONTROL_IMPLICIT_SOLUTION
*CONTROL_IMPLICIT_SOLVER
*CONTROL_IMPLICIT_STABILIZATION
*CONTROL_IMPLICIT_TERMINATION
*CONTROL_MPP_DECOMPOSITION_AUTOMATIC
*CONTROL_MPP_DECOMPOSITION_CHECK_SPEED
*CONTROL_MPP_DECOMPOSITION_CONTACT_DISTRIBUTE
*CONTROL_MPP_DECOMPOSITION_CONTACT_ISOLATION
*CONTROL_MPP_DECOMPOSITION_FILE
*CONTROL_MPP_DECOMPOSITION_METHOD
*CONTROL_MPP_DECOMPOSITION_NUMPROC
*CONTROL_MPP_DECOMPOSITION_SHOW
*CONTROL_MPP_DECOMPOSITION_TRANSFORMATION
*CONTROL_MPP_IO_LSTC_REDUCE
*CONTROL_MPP_IO_NOD3DUMP
*CONTROL_MPP_IO_NODUMP
*CONTROL_MPP_IO_NOFULL
*CONTROL_MPP_IO_SWAPBYTES
*CONTROL_OUTPUT
*CONTROL_PARALLEL
*CONTROL_REMESHING
*CONTROL_RIGID
*CONTROL_SHELL
*CONTROL_SOLID
*CONTROL_SOLUTION
*CONTROL_SPH
*CONTROL_SPOTWELD_BEAM
*CONTROL_STRUCTURED
*CONTROL_STRUCTURED_TERM
*CONTROL_SUBCYCLE
*CONTROL_TERMINATION
*CONTROL_THERMAL_NONLINEAR
*CONTROL_THERMAL_SOLVER
*CONTROL_THERMAL_TIMESTEP
*CONTROL_TIMESTEP
*DAMPING_FREQUENCY_RANGE
*DAMPING_GLOBAL
*DAMPING_PART_MASS
*DAMPING_PART_MASS_SET
*DAMPING_PART_STIFFNESS
*DAMPING_PART_STIFFNESS_SET
*DAMPING_RELATIVE
*DATABASE_ABSTAT
*DATABASE_ABSTAT_CPM
*DATABASE_AVSFLT
*DATABASE_BINARY_D3PART
*DATABASE_BINARY_D3PLOT
*DATABASE_BINARY_D3DRLF
*DATABASE_BINARY_D3THDT
*DATABASE_BINARY_D3DUMP
*DATABASE_BINARY_FSIFOR
*DATABASE_BINARY_INTFOR
*DATABASE_BINARY_RUNRSF
*DATABASE_BINARY_XTFILE
*DATABASE_BNDOUT
*DATABASE_CROSS_SECTION_PLANE(ID)
*DATABASE_CROSS_SECTION_SET(ID)
*DATABASE_DCFAIL
*DATABASE_DEFGEO
*DATABASE_DEFORC
*DATABASE_ELOUT
*DATABASE_EXTENT_AVS
*DATABASE_EXTENT_BINARY
*DATABASE_EXTENT_D3PART
*DATABASE_EXTENT_MOVIE
*DATABASE_EXTENT_MPGS
*DATABASE_EXTENT_SSSTAT
*DATABASE_FORMAT
*DATABASE_FSI
*DATABASE_GCEOUT
*DATABASE_GLSTAT
*DATABASE_HISTORY_BEAM(ID)
*DATABASE_HISTORY_BEAM_SET
*DATABASE_DISCRETE
*DATABASE_DISCRETE_SET
*DATABASE_HISTORY_NODE(ID)
*DATABASE_HISTORY_NODE_LOCAL(ID)
*DATABASE_HISTORY_NODE_SET
*DATABASE_HISTORY_NODE_SET_LOCAL
*DATABASE_HISTORY_NODE_SET_LOCAL(ID)
*DATABASE_HISTORY_SEATBELT
*DATABASE_HISTORY_SHELL
*DATABASE_HISTORY_SHELL(ID)
*DATABASE_HISTORY_SHELL_SET
*DATABASE_HISTORY_SOLID
*DATABASE_HISTORY_SOLID(ID)
*DATABASE_HISTORY_SOLID_SET
*DATABASE_HISTORY_SPH
*DATABASE_HISTORY_TSHELL
*DATABASE_HISTORY_TSHELL(ID)
*DATABASE_HISTORY_TSHELL_SET
*DATABASE_JNTFORC
*DATABASE_MASSOUT
*DATABASE_MATSUM
*DATABASE_MOVIE
*DATABASE_MPGS
*DATABASE_NCFORC
*DATABASE_NODAL_FORCE_GROUP
*DATABASE_NODFOR
*DATABASE_NODOUT
*DATABASE_OPTION
*DATABASE_RBDOUT
*DATABASE_RCFORC
*DATABASE_RWFORC
*DATABASE_SBTOUT
*DATABASE_SECFORC
*DATABASE_SLEOUT
*DATABASE_SPCFORC
*DATABASE_SPHOUT
*DATABASE_SPRING_FORWARD
*DATABASE_SSSTAT
*DATABASE_SUPERELASTIC_FORMING
*DATABASE_SWFORC
*DATABASE_TPRINT
*DATABASE_TRACER
*DATABASE_TRHIST
*DEFINE_ALEBAG_BAG
*DEFINE_ALEBAG_HOLE
*DEFINE_ALEBAG_INFLATOR
*DEFINE_BOX
*DEFINE_BOX_ADAPTIVE
*DEFINE_BOX_COARSEN
*DEFINE_BOX_DRAWBEAD
*DEFINE_BOX_SPH
*DEFINE_CONNECTION_PROPERTIES
*DEFINE_COORDINATE_NODES
*DEFINE_COORDINATE_SYSTEM
*DEFINE_COORDINATE_VECTOR
*DEFINE_CURVE
*DEFINE_CURVE_FEEDBACK
*DEFINE_CURVE_SMOOTH
*DEFINE_CURVE_TRIM
*DEFINE_CURVE_TRIM_3D
*DEFINE_HEX_SPOTWELD_ASSEMBLY
*DEFINE_HEX_SPOTWELD_ASSEMBLY_N
*DEFINE_SD_ORIENTATION
*DEFINE_TABLE
*DEFINE_TRANSFORMATION
*DEFINE_VECTOR
*DEFORMABLE_TO_RIGID
*DEFORMABLE_TO_RIGID_AUTOMATIC
*DEFORMABLE_TO_RIGID_INERTIA
*ELEMENT_BEAM
*ELEMENT_BEAM_OFFSET
*ELEMENT_BEAM_OFFSET_PID
*ELEMENT_BEAM_OFFSET_THICKNESS
*ELEMENT_BEAM_ORIENTATION
*ELEMENT_BEAM_PID
*ELEMENT_BEAM_SCALAR
*ELEMENT_BEAM_THICKNESS
*ELEMENT_DISCRETE
*ELEMENT_INERTIA
*ELEMENT_INERTIA_OFFSET
*ELEMENT_MASS
*ELEMENT_MASS_NODE_SET
*ELEMENT_MASS_PART
*ELEMENT_MASS_PART_SET
*ELEMENT_PLOTEL
*ELEMENT_SEATBELT
*ELEMENT_SEATBELT_ACCELEROMETER
*ELEMENT_SEATBELT_PRETENSIONER
*ELEMENT_SEATBELT_RETRACTOR
*ELEMENT_SEATBELT_SENSOR
*ELEMENT_SEATBELT_SLIPRING
*ELEMENT_SHELL
*ELEMENT_SHELL_BETA
*ELEMENT_SHELL_BETA_OFFSET
*ELEMENT_SHELL_COMPOSITE
*ELEMENT_SHELL_DOF
*ELEMENT_SHELL_MCID
*ELEMENT_SHELL_MCID_OFFSET
*ELEMENT_SHELL_OFFSET
*ELEMENT_SHELL_THICKNESS
*ELEMENT_SHELL_THICKNESS_BETA
*ELEMENT_SHELL_THICKNESS_BETA_OFFSET
*ELEMENT_SHELL_THICKNESS_MCID
*ELEMENT_SHELL_THICKNESS_MCID_OFFSET
*ELEMENT_SHELL_THICKNESS_OFFSET
*ELEMENT_SOLID
*ELEMENT_SOLID_ORTHO
*ELEMENT_SOLID_TET4TOTET10
*ELEMENT_SPH
*ELEMENT_TRIM
*ELEMENT_TSHELL
*END
*EOS_GRUNEISEN (EOS 4)
*EOS_IDEAL_GAS (EOS 12)
*EOS_IGNITION_AND_GROWTH_OF_REACTION_IN_HE (EOS 7)
*EOS_JWL (EOS 2)
*EOS_LINEAR_POLYNOMIAL (EOS 1)
*EOS_LINEAR_POLYNOMIAL_WITH_ENERGY_LEAK (EOS 6)
*EOS_PROPELLANT_DEFLAGRATION (EOS 10)
*EOS_RATIO_OF_POLYNOMIALS (EOS 5)
*EOS_SACK_TUESDAY (EOS 3)
*EOS_TABULATED (EOS 9)
*EOS_TABULATED_COMPACTION (EOS 8)
*EOS_TENSOR_PORE_COLLAPSE (EOS11)
*HOURGLASS
*INCLUDE_COMPENSATION
*INCLUDE_COMPENSATION_BLANK_AFTER_SPRINGBACK
*INCLUDE_COMPENSATION_BLANK_BEFORE_SPRINGBACK
*INCLUDE_COMPENSATION_COMPENSATED_SHAPE
*INCLUDE_COMPENSATION_DESIRED_BLANK_SHAPE
*INCLUDE_CURRENT_TOOLS
*INCLUDE_PATH
*INCLUDE_STAMPED_PART
*INCLUDE_STAMPED_PART_SET
*INCLUDE_TRANSFORM
*INITIAL_AXIAL_FORCE_BEAM
*INITIAL_DETONATION
*INITIAL_FOAM_REFERENCE_GEOMETRY
*INITIAL_GAS_MIXTURE
*INITIAL_MOMENTUM
*INITIAL_STRAIN_SHELL
*INITIAL_STRAIN_SOLID
*INITIAL_STRESS_BEAM
*INITIAL_STRESS_SECTION
*INITIAL_STRESS_SHELL
*INITIAL_STRESS_SOLID
*INITIAL_TEMPERATURE_NODE
*INITIAL_TEMPERATURE_SET
*INITIAL_VEHICLE_KINEMATICS
*INITIAL_VELOCITY
*INITIAL_VELOCITY_GENERATION
*INITIAL_VELOCITY_GENERATION_START_TIME
*INITIAL_VELOCITY_NODE
*INITIAL_VELOCITY_RIGID_BODY
*INITIAL_VOID
*INITIAL_VOLUME_FRACTION
*INITIAL_VOLUME_FRACTION_GEOMETRY
*INTEGRATION_BEAM
*INTEGRATION_SHELL
*INTERFACE_COMPENSATION_NEW
*INTERFACE_COMPONENT_NODE
*INTERFACE_COMPONENT_SEGMENT
*INTERFACE_LINKING_DISCRETE_NODE_SET
*INTERFACE_LINKING_EDGE
*INTERFACE_LINKING_SEGMENT
*INTERFACE_SPRINGBACK
*INTERFACE_SPRINGBACK_LSDYNA
*INTERFACE_SPRINGBACK_LSDYNA_NOTHICKNESS
*INTERFACE_SPRINGBACK_LSDYNA_THICKNESS
*INTERFACE_SPRINGBACK_NASTRAN
*INTERFACE_SPRINGBACK_NASTRAN_NOTHICKNESS
*INTERFACE_SPRINGBACK_NASTRAN_THICKNESS
*INTERFACE_SPRINGBACK_SEAMLESS
*INTERFACE_SPRINGBACK_SEAMLESS_NOTHICKNESS
*INTERFACE_SPRINGBACK_SEAMLESS_THICKNESS
*LOAD_BEAM_ELEMENT
*LOAD_BEAM_SET
*LOAD_BLAST
*LOAD_BODY_GENERALIZED
*LOAD_BODY_PARTS
*LOAD_BODY_RX
*LOAD_B0DY_RY
*LOAD_BODY_RZ
*LOAD_BODY_X
*LOAD_BODY_Y
*LOAD_BODY_Z
*LOAD_BRODE
*LOAD_MASK
*LOAD_NODE_POINT
*LOAD_NODE_SET
*LOAD_RIGID_BODY
*LOAD_SEGMENT
*LOAD_SEGMENT_ID
*LOAD_SEGMENT_SET_ID
*LOAD_SHELL_ELEMENT
*LOAD_SHELL_ELEMENT_ID
*LOAD_SHELL_PRESSURE
*LOAD_SHELL_SET_ID
*LOAD_SUPERELASTIC_FORMING
*LOAD_THERMAL_CONSTANT
*LOAD_THERMAL_CONSTANT_NODE
*LOAD_THERMAL_LOAD_CURVE
*LOAD_THERMAL_VARIABLE
*LOAD_THERMAL_VARIABLE_NODE
*LOAD_THERMAL_VARIABLE_SHELL
*LOAD_THERMAL_VARIABLE_SHELL_SET
*MAT_ACOUSTIC (*MAT_090)
*MAT_ADD_EROSION
*MAT_ALE_INCOMPRESSIBLE (*MAT_160)
*MAT_ANISOTROPIC_ELASTIC (*MAT_002_ANIS)
*MAT_ANISOTROPIC_ELASTIC_PLASTIC (*MAT_157)
*MAT_ANISOTROPIC_PLASTIC (*MAT_103_P)
*MAT_ANISOTROPIC_VISCOPLASTIC (*MAT_103)
*MAT_ARRUDA_BOYCE_RUBBER (*MAT_127)
*MAT_ARUP_ADHESIVE (*MAT_169)
*MAT_BAMMAN (*MAT_051)
*MAT_BAMMAN_DAMAGE (*MAT_052)
*MAT_BARLAT_ANISOTROPIC_PLASTICITY (*MAT_033)
*MAT_BARLAT_YLD2000 (*MAT_133)
*MAT_BARLAT_YLD96
*MAT_BILKHU/DUBOIS_FOAM (*MAT_075)
*MAT_BLATZ-KO_FOAM (*MAT_038)
*MAT_BLATZ-KO_RUBBER (*MAT_007)
*MAT_BOLT_BEAM (*MAT_208)
*MAT_BRITTLE_DAMAGE (*MAT_096)
*MAT_CABLE_DISCRETE_BEAM (*MAT_071)
*MAT_CELLULAR_RUBBER (*MAT_087)
*MAT_COHESIVE_ELASTIC (*MAT_184)
*MAT_COHESIVE_GENERAL (*MAT_185)
*MAT_COHESIVE_MIXED_MODE (*MAT_138)
*MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE (*MAT_240)
*MAT_COHESIVE_TH (*MAT_185)
*MAT_CLOSED_CELL_FOAM (*MAT_053)
*MAT_CODAM2 (*MAT_219)
*MAT_COMPOSITE_DAMAGE (*MAT_022)
*MAT_COMPOSITE_FAILURE_MODEL
*MAT_COMPOSITE_FAILURE_SHELL_MODEL (*MAT_059_SHELL)
*MAT_COMPOSITE_FAILURE_SOLID_MODEL (*MAT_059_SOLID)
*MAT_COMPOSITE_LAYUP (*MAT_116)
*MAT_COMPOSITE_MATRIX (*MAT_117)
*MAT_COMPOSITE_MSC (*MAT_161)
*MAT_COMPOSITE_MSC_DMG (*MAT_162)
*MAT_CONCRETE_DAMAGE (*MAT_072)
*MAT_CONCRETE_DAMAGE_REL3 (*MAT_072R3)
*MAT_CONCRETE_EC2 (*MAT_172)
*MAT_CORUS_VEGTER (*MAT_136)
*MAT_CRUSHABLE_FOAM (*MAT_063)
*MAT_CSCM (*MAT_159)
*MAT_CSCM_CONCRETE (*MAT_159_CONCRETE)
*MAT_DAMPER_NONLINEAR_VISCUOUS (*MAT_S05)
*MAT_DAMPER_VISCOUS (*MAT_S02)
*MAT_DESHPANDE_FLECK_FOAM (*MAT_154)
*MAT_ELASTIC (*MAT_001)
*MAT_ELASTIC_FLUID (*MAT_001_FLUID)
*MAT_ELASTIC_PLASTIC_HYDRO (*MAT_010)
*MAT_ELASTIC_PLASTIC_THERMAL (*MAT_004)
*MAT_ELASTIC_SPRING_DISCRETE_BEAM (*MAT_074)
*MAT_ELASTIC_VISCOPLASTIC_THERMAL (*MAT_106)
*MAT_ELASTIC_WITH_VISCOSITY (*MAT_060)
*MAT_ELASTIC_6DOF_SPRING_DISCRETE_BEAM (*MAT_093)
*MAT_EMMI (*MAT_151)
*MAT_ENHANCED_COMPOSITE_DAMAGE (*MAT_054)
*MAT_FABRIC (*MAT_034)
*MAT_FINITE_ELASTIC_STRAIN_PLASTICITY (*MAT_112)
*MAT_FLD_TRANSVERSELY_ANISOTROPIC (*MAT_039)
*MAT_FLD_3_PARAMETER_BARLAT (*MAT_190)
*MAT_FORCE_LIMITED (*MAT_029)
*MAT_FRAZER_NASH_RUBBER_MODEL (*MAT_031)
*MAT_FU_CHANG_FOAM_DAMAGE_DECAY (*MAT_083_DAMAGE_DECAY)
*MAT_FU_CHANG_FOAM (*MAT_083)
*MAT_GAS_MIXTURE (*MAT_148)
*MAT_GENERAL_JOINT_DISCRETE_BEAM (*MAT_097)
*MAT_GENERAL_NONLINEAR_1DOF_DISCRETE_BEAM (*MAT_121)
*MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM (*MAT_119)
*MAT_GENERAL_SPRING_DISCRETE_BEAM
*MAT_GENERAL_VISCOELASTIC (*MAT_076)
*MAT_GEOLOGIC_CAP_MODEL (*MAT_025)
*MAT_GEPLASTIC_SRATE_2000a (*MAT_101)
*MAT_GURSON (*MAT_120)
*MAT_GURSON_JC (*MAT_120_JC)
*MAT_GURSON_RCDC (*MAT_120_RCDC)
*MAT_HIGH_EXPLOSIVE_BURN (*MAT_008)
*MAT_HILL_FOAM (*MAT_177)
*MAT_HILL_3R (*MAT_122)
*MAT_HILL_90 (*MAT_243)
*MAT_HONEYCOMB (*MAT_026)
*MAT_HYDRAULIC_GAS_DAMPER_DISCRETE_BEAM (*MAT_070)
*MAT_HYPERELASTIC_RUBBER (*MAT_077_H)
*MAT_INELASTIC_SPRING_DISCRETE_BEAM (*MAT_094)
*MAT_INELASTIC_6DOF_SPRING_DISCRETE_BEAM (*MAT_095)
*MAT_ISOTROPIC_ELASTIC_FAILURE (*MAT_013)
*MAT_ISOTROPIC_ELASTIC_PLASTIC (*MAT_012)
*MAT_JOHNSON_COOK (*MAT_015)
*MAT_JOHNSON_HOLMQUIST_CERAMICS (*MAT_110)
*MAT_JOHNSON_HOLMQUIST_CONCRETE (*MAT_111)
*MAT_JOHNSON_HOLMQUIST_JH1 (*MAT_241)
*MAT_KELVIN-MAXWELL_VISCOELASTIC (*MAT_061)
*MAT_KINEMATIC_HARDENING_BARLAT2000 (*MAT_242)
*MAT_KINEMATIC_HARDENING_BARLAT89 (*MAT_226)
*MAT_KINEMATIC_HARDENING_TRANSVERSELY_ANISOTROPIC (*MAT_125)
*MAT_LAMINATED_COMPOSITE_FABRIC (*MAT_058)
*MAT_LAMINATED_GLASS (*MAT_032)
*MAT_LAYERED_LINEAR_PLASTICITY (*MAT_114)
*MAT_LINEAR_ELASTIC_DISCRETE_BEAM (*MAT_066)
*MAT_LOW_DENSITY_FOAM (*MAT_057)
*MAT_LOW_DENSITY_SYNTHETIC_FOAM (*MAT_179)
*MAT_LOW_DENSITY_SYNTHETIC_FOAM_ORTHO (*MAT_180)
*MAT_LOW_DENSITY_SYNETHIC_FOAM_ORTHO_WITH_FAILURE (*MAT_180_WITH_FAILURE)
*MAT_LOW_DENSITY_SYNTHETIC_FOAM_WITH_FAILURE (*MAT_179_WITH_FAILURE)
*MAT_LOW_DENSITY_VISCOUS_FOAM (*MAT_073)
*MAT_MICROMECHANICS_DRY_FABRIC (*MAT_235)
*MAT_MODIFIED_CRUSHABLE_FOAM (*MAT_163)
*MAT_MODIFIED_HONEYCOMB (*MAT_126)
*MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY (*MAT_123)
*MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY_RATE (*MAT_123_RATE)
*MAT_MODIFIED_PIECEWISE_LINEAR_PLASTICITY_RTCL (*MAT_123_RTCL)
*MAT_MODIFIED_ZERILLI_ARMSTRONG (*MAT_065)
*MAT_MOMENT_CURVATURE_BEAM (*MAT_166)
*MAT_MOONEY_RIVLIN_RUBBER (*MAT_027)
*MAT_MTS (*MAT_088)
*MAT_NONLINEAR_ELASTIC_DISCRETE_BEAM (*MAT_067)
*MAT_NONLINEAR_ORTHOTROPIC (*MAT_040)
*MAT_NONLINEAR_PLASTIC_DISCRETE_BEAM (*MAT_068)
*MAT_NULL (*MAT_009)
*MAT_OGDEN_RUBBER (*MAT_077_O)
*MAT_ORIENTED_CRACK (*MAT_017)
*MAT_ORTHOTROPIC_ELASTIC (*MAT_002)
*MAT_ORTHOTROPIC_SIMPLIFIED_DAMAGE (*MAT_221)
*MAT_ORTHOTROPIC_THERMAL (*MAT_021)
*MAT_ORTHOTROPIC_VISCOELASTIC (*MAT_086)
*MAT_PIECEWISE_LINEAR_PLASTICITY (*MAT_024)
*MAT_PLASTICITY_COMPRESSION_TENSION (*MAT_124)
*MAT_PLASTICITY_COMPRESSION_TENSION_E0S (*MAT_155)
*MAT_PLASTIC_KINEMATIC (*MAT_003)
*MAT_PLASTICITY_POLYMER (*MAT_089)
*MAT_PLASTICITY_WITH_DAMAGE (*MAT_081/*MAT_082)
*MAT_PLASTICITY_WITH_DAMAGE_ORTHO (*MAT_081_ORTHO)
*MAT_PLASTICITY_WITH_DAMAGE_ORTHO_RCDC (*MAT_082_ORTHO_RCDC)
*MAT_PML_ELASTIC (*MAT_230)
*MAT_PML_ELASTIC_FLUID (*MAT_230_FLUID)
*MAT_POLYMER (*MAT_168)
*MAT_POWDER (*MAT_271)
*MAT_POWER_LAW_PLASTICITY (*MAT_018)
*MAT_PSEUDO_TENSOR (*MAT_016)
*MAT_RATE_SENSITIVE_POWERLAW_PLASTICITY (*MAT_064)
*MAT_RATE_SENSITIVE_POLYMER (*MAT_141)
*MAT_RESULTANT_ANISOTROPIC (*MAT_170)
*MAT_RESULTANT_PLASTICITY (*MAT_028)
*MAT_RIGID (*MAT_020)
*MAT_RIGID_DISCRETE (*MAT_220)
*MAT_SAMP-1 (*MAT_187)
*MAT_SCHWER_MURRARY_CAP_MODEL (*MAT_145)
*MAT_SEATBELT (*MAT_B01)
*MAT_SEISMIC_BEAM (*MAT_191)
*MAT_SHAPE_MEMORY (*MAT_030)
*MAT_SID_DAMPER_DISCRETE_BEAM (*MAT_069)
*MAT_SIMPLIFIED_JOHNSON_COOK (*MAT_098)
*MAT_SIMPLIFIED_JOHNSON_COOK_ORTHOTROPIC_DAMAGE (*MAT_099)
*MAT_SIMPLIFIED_RUBBER
*MAT_SIMPLIFIED_RUBBER_FOAM (*MAT_181)
*MAT_SIMPLIFIED_RUBBER_FOAM_WITH_FAILURE (*MAT_181_WITH_FAILURE)
*MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE (*MAT_183)
*MAT_SOIL_AND_FOAM
*MAT_SOIL_AND_FOAM_FAILURE (*MAT_014)
*MAT_SOIL_CONCRETE (*MAT_078)
*MAT_SPECIAL_ORTHOTROPIC (*MAT_130)
*MAT_SPOTWELD (*MAT_100)
*MAT_SPOTWELD_DAIMLERCHRYSLER (*MAT_100_DAIMLERCHRYSLER)
*MAT_SPOTWELD_DAMAGE-FAILURE (*MAT_100_DAMAGE-FAILURE)
*MAT_SPRING_ELASTIC (*MAT_S01)
*MAT_SPRING_ELASTOPLASTIC (*MAT_S03)
*MAT_SPRING_GENERAL_NONLINEAR (*MAT_S06)
*MAT_SPRING_INELASTIC (*MAT_S08)
*MAT_SPRING_MAXWELL (*MAT_S07)
*MAT_SPRING_NONLINEAR_ELASTIC (*MAT_S04)
*MAT_STEINBERG (*MAT_011)
*MAT_STEINBERG_LUND (*MAT_011_LUND)
*MAT_STRAIN_RATE_DEPENDENT_PLASTICITY (*MAT_019)
*MAT_TABULATED_JOHNSON_COOK (*MAT_224)
*MAT_TEMPERATURE_DEPENDENT_ORTHOTROPIC (*MAT_023)
*MAT_THERMAL_ISOTROPIC (*MAT_T01)
*MAT_THERMAL_ISOTROPIC_TD_LC (*MAT_T06)
*MAT_THERMAL_ORTHOTROPIC (*MAT_T02)
*MAT_THERMO_ELASTO_VISCOPLASTIC_CREEP (*MAT_188)
*MAT_TRANSVERSELY_ANISOTROPIC_CRUSHABLE_FOAM (*MAT_142)
*MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC (*MAT_037)
*MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC_ECHANGE (*MAT_037_ECHANGE)
*MAT_TRANSVERSELY_ANISOTROPIC_ELASTIC_PLASTIC_NLP_FAILURE (*MAT_037_NLP_FAILURE)
*MAT_TRIP (*MAT_113)
*MAT_UHS_STEEL (*MAT_244)
*MAT_UNSUPPORTED
*MAT_USER_DEFINED_MATERIAL
*MAT_VACUUM (*MAT_140)
*MAT_VISCOELASTIC (*MAT_006)
*MAT_VISCOELASTIC_HILL_FOAM (*MAT_178)
*MAT_VISCOELASTIC_LOOSE_FABRIC (*MAT_234)
*MAT_VISCOPLASTIC_MIXED_HARDENING (*MAT_225)
*MAT_VISCOUS_FOAM (*MAT_062)
*MAT_WINFRITH_CONCRETE (*MAT_084)
*MAT_WOOD (*MAT_143)
*MAT_WOOD_FIR (*MAT_143_FIR)
*MAT_WOOD_OPTION
*MAT_WOOD_PINE (*MAT_143_PINE)
*MAT_WTM_STM_PLC (*MAT_135_PLC)
*MAT_1DOF_GENERALIZED_SPRING (*MAT_146)
*MAT_3-PARAMETER_BARLAT (*MAT_036)
*MAT_3-PARAMETER_BARLAT_NLP (*MAT_036_NLP)
*NODE
*NODE_RIGID_SURFACE
*NODE_TRANSFORM
*PARAMETER
*PARAMETER_EXPRESSION
*PART
*PART_COMPOSITE
*PART_COMPOSITE_CONTACT
*PART_COMPOSITE_TSHELL
*PART_CONTACT
*PART_CONTACT_PRINT
*PART_INERTIA
*PART_INERTIA_CONTACT
*PART_INERTIA_CONTACT_PRINT
*PART_INERTIA_PRINT
*PART_MOVE
*PART_PRINT
*PART_REPOSITION
*PART_REPOSITION_CONTACT
*PART_REPOSITION_CONTACT_PRINT
*PART_REPOSITION_PRINT
*PART_SENSOR
*RIGIDWALL_GEOMETRIC_CYLINDER
*RIGIDWALL_GEOMETRIC_CYLINDER_DISPLAY
*RIGIDWALL_GEOMETRIC_CYLINDER_MOTION
*RIGIDWALL_GEOMETRIC_CYLINDER_MOTION_DISPLAY
*RIGIDWALL_GEOMETRIC_FLAT
*RIGIDWALL_GEOMETRIC_FLAT(FINITE)
*RIGIDWALL_GEOMETRIC_FLAT_DISPLAY
*RIGIDWALL_GEOMETRIC_FLAT_DISPLAY(FINITE)
*RIGIDWALL_GEOMETRIC_FLAT_MOTION
*RIGIDWALL_GEOMETRIC_FLAT_MOTION(FINITE)
*RIGIDWALL_GEOMETRIC_FLAT_MOTION_DISPLAY
*RIGIDWALL_GEOMETRIC_FLAT_MOTION_DISPLAY(FINITE)
*RIGIDWALL_GEOMETRIC_PRISM
*RIGIDWALL_GEOMETRIC_PRISM(FINITE)
*RIGIDWALL_GEOMETRIC_PRISM_DISPLAY
*RIGIDWALL_GEOMETRIC_PRISM_DISPLAY(FINITE)
*RIGIDWALL_GEOMETRIC_PRISM_MOTION
*RIGIDWALL_GEOMETRIC_PRISM_MOTION(FINITE)
*RIGIDWALL_GEOMETRIC_PRISM_MOTION_DISPLAY
*RIGIDWALL_GEOMETRIC_PRISM_MOTION_DISPLAY(FINITE)
*RIGIDWALL_GEOMETRIC_SPHERE
*RIGIDWALL_GEOMETRIC_SPHERE_DISPLAY
*RIGIDWALL_GEOMETRIC_SPHERE_MOTION
*RIGIDWALL_GEOMETRIC_SPHERE_MOTION_DISPLAY
*RIGIDWALL_PLANAR
*RIGIDWALL_PLANAR_FINITE
*RIGIDWALL_PLANAR_FINITE_FORCES
*RIGIDWALL_PLANAR_FINITE_MOVING
*RIGIDWALL_PLANAR_FINITE_MOVING_DISPLAY
*RIGIDWALL_PLANAR_FINITE_MOVING_FORCES
*RIGIDWALL_PLANAR_FINITE_MOVING_FORCES_DISPLAY
*RIGIDWALL_PLANAR_FORCES
*RIGIDWALL_PLANAR_MOVING
*RIGIDWALL_PLANAR_MOVING_DISPLAY
*RIGIDWALL_PLANAR_MOVING_FORCES
*RIGIDWALL_PLANAR_MOVING_FORCES_DISPLAY
*RIGIDWALL_PLANAR_ORTHO
*RIGIDWALL_PLANAR_ORTHO_FINITE
*RIGIDWALL_PLANAR_ORTHO_FINITE_FORCES
*RIGIDWALL_PLANAR_ORTHO_FORCES
*SECTION_BEAM(TITLE)
*SECTION_DISCRETE(TITLE)
*SECTION_POINT_SOURCE(TITLE)
*SECTION_POINT_SOURCE_MIXTURE(TITLE)
*SECTION_SEATBELT(TITLE)
*SECTION_SHELL(TITLE)
*SECTION_SHELL_ALE(TITLE)
*SECTION_SHELL_EFG(TITLE)
*SECTION_SOLID(TITLE)
*SECTION_SOLID_ALE(TITLE)
*SECTION_SOLID_EFG(TITLE)
*SECTION_SPH
*SECTION_TSHELL(TITLE)
*SENSOR_CONTROL
*SENSOR_DEFINE_CALC_MATH
*SENSOR_DEFINE_ELEMENT
*SENSOR_DEFINE_FORCE
*SENSOR_DEFINE_NODE
*SENSOR_SWITCH
*SENSOR_SWITCH_CALC_LOGIC
*SET_BEAM(TITLE)
*SET_BEAM_ADD
*SET_BEAM_GENERATE(TITLE)
*SET_DISCRETE(TITLE)
*SET_DISCRETE_ADD
*SET_DISCRETE_GENERAL
*SET_DISCRETE_GENERATE(TITLE)
*SET_MULTI_MATERIAL_GROUP_LIST(TITLE)
*SET_NODE_ADD
*SET_NODE_ADD_ADVANCED
*SET_NODE_COLUMN
*SET_NODE_LIST(TITLE)
*SET_NODE_LIST_GENERATE(TITLE)
*SET_PART_ADD
*SET_PART_COLUMN(TITLE)
*SET_PART_LIST_GENERATE(TITLE)
*SET_SEGMENT
*SET_SEGMENT(TITLE)
*SET_SEGMENT_GENERAL
*SET_SEGMENT_GENERATE(TITLE)
*SET_SHELL_ADD
*SET_SHELL_COLUMN
*SET_SHELL_LIST(TITLE)
*SET_SHELL_LIST_GENERATE(TITLE)
*SET_SOLID(TITLE)
*SET_SOLID_ADD
*SET_SOLID_ADD(TITLE)
*SET_SOLID_GENERAL
*SET_SOLID_GENERAL(TITLE)
*SET_SOLID_GENERATE(TITLE)
*SET_TSHELL(TITLE)
*SET_TSHELL_GENERAL
*SET_TSHELL_GENERAL(TITLE)
*SET_TSHELL_GENERATE(TITLE)
*SPRINGBACK
*STRESS_INITIALIZATION
*STRESS_INITIALIZATION_DISCRETE
*STRESS_INITIALIZATION_SEATBELT
hmtoggle_arrow1NASTRAN
The following cards are supported in Nastran:
ACMODL
AEFACT
ASCRCE
ASET
ASET1
AUTOSPC
BCBODY
BCBODY1
BCDPRP
BCONECT
BCONPRG
BCONPRP
BCPARA
BCPROP
BCTABLE
BCTABL1
BCTSET
BEGIN BULK
BMFACE
BNDFREE1
BNDFX1
BOLT
BOLTFOR
BSET1
BSURF
BSURFS
BULK-UNSUPPORTED_CARD
CAABSF
CACINF3
CACINF4
CAERO1
CAERO2
CASE-UNSUPPORTED CARD
CBAR
CBEAM
CBEND
CBUSH
CBUSH1D
CDAMP1
CDAMP2
CDAMP3
CDAMP4
CELAS1
CELAS2
CELAS3
CELAS4
CEND
CFAST
CGAP
CHACAB
CHBDYE
CHBDYP
CHEXA (20-noded)
CHEXA (8-noded)
CMASS1
CMASS2
CMASS3
CMASS4
CONM1
CONM2
CONROD
CONVECTION
CORD1C
CORD1R
CORD1S
CORD2C
CORD2R
CORD2S
CPENTA (6-noded)
CPENTA (15-noded)
CQUAD4
CQUAD8
CQUADR
CQUADX
CROD
CSET1
CSHEAR
CSUPER
CSUPEXT
CTETRA (4-noded)
CTETRA (10-noded)
CTRIA3
CTRIA6
CTRIAX
CTRIAX6
CTRIAR
CTUBE
CVISC
CWELD
DAMPING
DAREA
DCONADD
DCONSTR
DDVAL
DEFORM
DELAY
DEQATN
DESGLB
DESOBJ
DESSUB
DESVAR
DIAG
DLINK
DLINK2
DLOAD
DOPTPRM
DPHASE
DRESP1
DRESP2
DSCREEN
DTABLE
DTISPECSEL
DVCREL1
DVCREL2
DVMREL1
DVMREL2
DVPREL1
DVPREL2
ECHO
EIGB
EIGC
EIGP
EIGR
EIGRL
ELIST
ENDDATA
ERP
ERPPNL
EXEC_UNSUPPORTED_CARDS
FLFACT
FLSPOUT
FLUTTER
FLUX
FORCE
FREQ
FREQ1
FREQ2
FREQ3
FREQ4
FREQ5
GENEL
GLOBAL CASE CONTROL
GLOBAL OUTPUT REQUEST
GRAV
GRDSET
GRID
HM_ELAS
HM_SPRING
HYBDAMP
ID
INCLUDE BULK
INCLUDE_CTRL
INCLUDE_EXEC
K2PP
LOAD
LOADSEQ
MARCOUT
MAT1
MAT2
MAT4
MAT5
MAT8
MAT9
MAT10
MATEP
MATG
MATHE
MATHP
MATS1
MATT1
MATT4
MAXLINES
MAXMIN
MBOLT
MBOLTUS
MFLUID
MINMAX
MOMENT
MONPNT
MPC
MPCADD
NLAUTO
NLDAMP
NLMOPTS
NLPARM
NLRGAP
NLSTEP
NLSTRAT
NOLIN1
NSMADD
NSM1
NSML1
NTHICK
OMIT1
OMIT_BEGIN_BULK
OMIT_CEND
OMIT_END_BULK
PAABSF
PACABS
PACBAR
PACINF
PAERO1
PAERO2
PANEL
PARAM
PAXSYMH
PBAR
PBARL
PBEAM
PBEAML
PBEND
PBUSH
PBUSH1D
PBUSHT
PCOMP
PCOMPG
PCONV
PCONVM
PDAMP
PELAS
PELAST
PFAST
PGAP
PHBDY
PLPLANE
PLOAD
PLOAD1
PLOAD2
PLOAD4
PLOTEL
PLSOLID
PMASS
PROD
PSEAM
PSHEAR
PSHELL
PSHLN1
PSOLID
PRESSURE
PTUBE
PVISC
PWELD
QBDY1
QSET1
QVOL
RADCAV
RADIATION
RADM
RADSET
RANDPS
RBAR
RBE2
RBE3
RESTART
RESVEC
RFORCE
RIGID
RJOINT
RLOAD1
RLOAD2
ROTORG
RROD
RSPEC
RSPINR
RSPINT
SEBNDRY
SEBSET1
SECSET1
SEQSET1
SESET
SET
SET (Control Card)
SET1
SEUSET1
SNORM
SOL
SPC
SPC1
SPCADD
SPCD
SPCR
SPOINT
SUBCASE
SUBCOM
SUBSEQ
SUBTITLE
SUPORT
SUPORT1
SWLDPRM
TABDMP1
TABLED1
TABLED2
TABLED3
TABLED4
TABLEM1
TABLEM2
TABLEM3
TABLEM4
TABLES1
TABLEST
TABRND1
TEMP
TEMPBC
TEMPD
TIC
TIME
TITLE
TLOAD1
TLOAD2
TRIM
TSTEP
TSTEPNL (Load Collector)
TSTEPNL (Control Card)
USET
USET1
VIEW
VIEW3D
hmtoggle_arrow1PAM-CRASH 2G
The following cards are supported in PAM-CRASH 2G:
ACC3D /
ACFLD /
ADAPT /
AIRBAGCHECK
ANALYSIS
ASSOCIATE
AUTOSLEEP
BAGIN /
BAR /
BASE_BODY
BEAM /
BELTS /
BDFOR /
BOUNC /
BSHEL /
CCTRL /
CHAMBER /
CNODE /
CNTAC / Type 1
CNTAC / Type 10
CNTAC / Type 13
CNTAC / Type 14
CNTAC / Type 15
CNTAC / Type 16
CNTAC / Type 17
CNTAC / Type 18
CNTAC / Type 19
CNTAC / Type 21
CNTAC / Type 33
CNTAC / Type 34
CNTAC / Type 36
CNTAC / Type 37
CNTAC / Type 43
CNTAC / Type 44
CNTAC / Type 46
CNTAC / Type 54
CNTAC / Type 154
CONLO /
COUPLING
DAMP /
DATACHECK
DCOMP
DEBUG
DIS3D /
DIS3DM /
DIS3DX /
ECTRL /
EDG
ELINK /
END_BAGIN
END_CHAMBER
ENDDATA
EXT_SKIN
FILE
FPM
FPM_HOLE
FRAME /
FRICT /
FUNCT /
GAS
GASPEC /
GEN_INI_COND
GES /
GROUP /
INCLU /
INFLATOR
INI_COND
INPUTVERSION
INVEL /
JET
JOINT /
KJOIN /
LEAKAGE
LLINK /
LOCAL_H
MASS
MASS_GES /
MAT_SECURE
MAXMEMORY
MBSYS /
MERGEGAP
MEMBR /
METRIC /
METRICCHECK
MTJOIN /
MTOCO /
NODCO /
NODE /
NSMAS /
OCTRL /
OTMCO /
PART /
PICK
PICKING /
PIPE
PLANE
PLINK /
PLINK_VI
PLY
PLYDATA
PREBM /
PREFA /
RAC3D /
RAN3D /
RBODY /
RDA3D /
RDD3D /
RDV3D /
RESTARTFILES
RETRA /
RVE3D /
RUNEND
RUPMO /
RWALL /
RWALL_KIN_CHECK
SECFO /
SECFO_CONTACT /
SECFO_PLANE /
SECFO_SECTION /
SECFO_SUPPORT /
SECFO_VOLFRAC /
SECTION
SEG
SENPT /
SENPTG /
SENSO /
SENSOR /
SHELL /
SHELLCHECK
SIGNAL
SLINK /
SLIPR /
SOLID /
SOLIDCHECK
SOLID4N
SOLVER
SPCTRL
SPH
SPRING /
SPRGBM /
STOPRUN
SUBDF /
SUBRUN
SUBTA /
SUPPORT
TCTRL /
TETRA /
TETR4 /
THELE /
THLOC /
THNOD /
TIED /
TITLE /
TRANSFORMATION /
TRSFM /
TSHEL /
TYPE 1
TYPE 2
TYPE 5
TYPE 7
TYPE 11
TYPE 16
TYPE 17
TYPE 18
TYPE 20
TYPE 21
TYPE 22
TYPE 25
TYPE 26
TYPE 30
TYPE 31
TYPE 36
TYPE 37
TYPE 41
TYPE 42
TYPE 45
TYPE 52
TYPE 61
TYPE 62
TYPE 71
TYPE 99
TYPE 100
TYPE 101
TYPE 102
TYPE 103
TYPE 105
TYPE 106
TYPE 107
TYPE 108
TYPE 109
TYPE 110
TYPE 115
TYPE 116
TYPE 117
TYPE 118
TYPE 121
TYPE 126
TYPE 128
TYPE 130
TYPE 131
TYPE 132
TYPE 143
TYPE 150
TYPE 151
TYPE 161
TYPE 162
TYPE 171
TYPE 200
TYPE 201
TYPE 202
TYPE 203
TYPE 204
TYPE 205
TYPE 212
TYPE 213
TYPE 214
TYPE 220
TYPE 221
TYPE 222
TYPE 223
TYPE 224
TYPE 230
TYPE 301
TYPE 302
TYPE 303
TYPE 304
UNIT
VEL3D /
VOLFRAC
WALL_FABRIC
WALL_OPENING
